Girgling sound from the rad - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-15-2005, 11:55 PM   #1 (permalink)
View Loan Wolf Cam87's Photo Gallery
2nd Generation Girgling sound from the rad
hey yall another test, im a little nervous, ive noticed in the last week at startup through my vents i can hear what kinda sounds like water girgiling, i think it goes away after the engine warms up
tonight when i got home i was curious and poped the hood (was driving for anhour or more) and there was definatly some mo fo girgiling coming from the rad, it stopped after about 5 minish.
should i be nervous? is there somethin wrong with her
One Monkey Don't Stop No Shiw
Loan Wolf Cam87 is offline   Reply With Quote
Old 04-16-2005, 12:03 AM   #2 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
check your coolant level and make sure they're plenty in the reservoir. make sure it looks fresh (bright green assuming you use green antifreeze).
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 04-16-2005, 08:13 AM   #3 (permalink)
alright ill check it out anyone else have any ideas
Old 04-16-2005, 09:18 AM   #4 (permalink)
if it's actually boiling over check the thermostat and make sure it's not stuck closed. It's like a $8 part plus a dollar for the gasket (Don't forget the gasket), so not a bad idea to replace it if in doubt.
