Scratched Wheels Self Repair ... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-17-2005, 06:03 AM   #1 (permalink)
99 Camry LE
View Gachinto's Photo Gallery
4th Generation Scratched Wheels Self Repair ...
planning to repair my scratched and "uglied" oem rims of my 99 camry le ~ any tips / suggestions plz ? this is my plan:
- paint strip and sand to bare metal/alloy
- clean and stuff
- "heavy coats" of primer <--
- gentle sand till smooth <--
- color and clear coat and stuff
Gachinto is offline   Reply With Quote
Old 04-17-2005, 08:55 AM   #2 (permalink)
Lost
Misctick's Avatar
View Misctick's Photo Gallery
to add another question , what kinda paint would you use , the high tempeture ressitant kind ?
Misctick is offline   Reply With Quote
Old 04-17-2005, 09:45 AM   #3 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
The make wheel paint that they sell at autozone and walmart, similar places.
I really don't know much besides taht about wheel painting.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
Old 04-17-2005, 09:58 AM   #4 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $911527
iTrader Score: 59 reviews
Are they alloy or steel?
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
eyeball96 is offline   Reply With Quote
Old 04-17-2005, 12:36 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
- clean and stuff
Sounds good.
Its better to do light coats then heavy coats. Heavy coats = chances for runs and drips, long drying time, etc...
1. Spray a few coats of primer, let it dry completely, then wetsand with 600 grit sandpaper.
Don't go crazy with the wetsanding, otherwise you'll remove all the paint.
2. Few more coats of primer, let it dry, then wetsand again.
3. Spray your color, let it dry, and wetsand. You can move up to 800 - 1000 grit sandpaper.
4. Repeat step 3.
5. Clear coat (few light coats), let it dry, and wetsand. Move up to 1500 - 2000 grit sandpaper.
6. Repeat step 5, except this time skip the wetsanding.
7. Once everything is done, you can use a fine cutting compound and polish.
P.S. Clean off and dry the wheels after each wetsanding session.
"Skoolin' the unlearned!"
Old 04-18-2005, 10:57 PM   #6 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
Check into powder coating.
old faithful
amerikim is offline   Reply With Quote
Old 04-19-2005, 03:55 AM   #7 (permalink)
99 Camry LE
stock 99 camry le rim ... the one with a hub cap in middle (i lost one of those thingy) ... i believe it's alloy i dunno ~
Old 04-19-2005, 05:42 AM   #8 (permalink)
View itzsteven's Photo Gallery
$30 to buy a new cap
Saving money for Ripp Header!
itzsteven is offline   Reply With Quote
