Help Removing trim - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2005, 01:44 PM   #1 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
Help Removing trim
does anyone have tricks for pics in removing the trim on a 1998 camry? i cant get the vents and rear window controllers out..
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 04-19-2005, 02:11 PM   #2 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
which vents?
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 04-19-2005, 04:05 PM   #3 (permalink)
-= CAMRY =-
front ones... now i seem to have problems removing the buttons.. i break alot of things so i'm being very carefull this time
Old 04-19-2005, 05:23 PM   #4 (permalink)
View .tony. .riot.'s Photo Gallery
I'm not sure what you're talking about.
Are you trying to remove the dash to be able to remove the gauge cluster?
If that's it, exactly what part are you having trouble with?
To remove the dash, first you need to remove the U trim under the stereo and the lighter plug. Unscrew the two bolts then remove the upper piece and you should get it from there.
.tony. .riot. is offline   Reply With Quote
Old 04-21-2005, 10:43 PM   #5 (permalink)
-= CAMRY =-
i got problems removing the heat vents. and the rear window buttons.
Old 04-21-2005, 10:49 PM   #6 (permalink)
What rear windor buttons? What are you talking about?
What do you need to remove the heat vents for?
Old 04-21-2005, 10:52 PM   #7 (permalink)
-= CAMRY =-
i'm painting the trim of my car. things where wood trim is suppose to be. so i have to take out these parts and spray paint it.
