Can a leaky/broken egr gasket cause stalling?
Well, I've had this stalling problem for months now, sometimes when coming to a stop, or stopped already, my car just stalls. Sometimes it cranks right back up, sometimes I have to hold the gas and crank it for a while (in bursts, even up to like 5 minutes). I've been talking to a Toyota mechanic online but he's from Oregon or something so I obviously can't have him work on my car. He says, from the symptoms I described, that it's most likely EGR related. I've inspected my distributor and it seems fine. I also replaced plugs and wires and more recently the valve cover gasket (unrelated, needed to be done anyway).
I finally found a way to get to that damn union nut that holds the EGR valve on. Anyway, so I finally get it off and the bottom left quarter of the EGR valve gasket is just missing (in such a way that air could move from in between the valve and the throttle body). I'm about to goto the parts store to see if they have them there so that I can replace it, but want to know if this could be causing the problem. Also, is it worthwhile to replace the whole EGR valve? the car is 10 years old after all and the outside of a good portion of the thing is rusted up.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
