How to take care of high mileage cars - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2005, 10:53 AM   #1 (permalink)
View toyocamboi's Photo Gallery
Question How to take care of high mileage cars
I have 1998 toyota camry 160,000 miles its a 6cyl tell me what all do i have to do to keep it running good all it has is tranmission oil change and regular oil change every 3000 mile.
BLk Camry 98-6cyl 1mz
toyocamboi is offline   Reply With Quote
Old 04-21-2005, 10:57 AM   #2 (permalink)
Every road's a playground
toyotaholic's Avatar
View toyotaholic's Photo Gallery
change spark plugs, wheel alignment, rotate tires, check tire pressure, and seafoam
toyotaholic is offline   Reply With Quote
Old 04-21-2005, 11:06 AM   #3 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
TLC...lots of it, something breaks or wears, fix it....speeding and beating on it will kill it fast, oil change every 3000 miles
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 04-21-2005, 11:06 AM   #4 (permalink)
thanks for the advice but?
what is seafom and where do can i buy it at and how do i use that
Old 04-21-2005, 11:17 AM   #5 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
^couldn't of said it better. oil change is the biggie, love it and it will love you back
vsixcamry is offline   Reply With Quote
Old 04-21-2005, 11:18 AM   #6 (permalink)
View .tony. .riot.'s Photo Gallery
Search for seafoam and you'll get a few threads. One of them is pretty recent which tells you some of the ways you can use seafoam on your camry with details.
.tony. .riot. is offline   Reply With Quote
Old 04-21-2005, 11:25 AM   #7 (permalink)
Knailgun's Avatar
best thing also with the cams and miles on them...is to put more....it isn't uncommon for 250,000 without major problems...just keep up on the TLC though
Old 04-21-2005, 12:20 PM   #8 (permalink)
tC
View 95camguy's Photo Gallery
ur 98 should last forever with basic maintenance. just check out the 200000+ miles club. its a huge list considering only .0000000000001% of camry owners are a member of TN.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 04-21-2005, 01:26 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
If thats all you've done, your way overdue for other stuff.
1. Timing belt (every 60,000 miles).
2. Accessory belts (replace them along with the timing belt).
3. Water pump (replace every 120,000 miles along with the timing belt).
4. Spark plugs
5. Check the spark plug wires.
6. Fluids (tranny, differential, coolant, etc..)
"Skoolin' the unlearned!"
Old 04-21-2005, 04:30 PM   #10 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
Transmission fluid doesnt need to be changed every 3000 more like every 10000-15000 w/new filter....ive even heard some places recomend as much as 30000 but i usually dont wait that long. i have a 93 camry v6 ...it had 210000 and was running better than most new cars. I recently had it rebuilt but it didnt really need it...i was just preparing for the boost thats to come on top of all the other mods i did. But like ppl have been saying...do basic maintanence and youll have it runnin a long long time...o and import thing to add when doing an oil change is Engine Restore that stuff in the silver can and pop top...costs like $5 but def makes a difference..it basically restores lost compression and it works.
ag6286 is offline   Reply With Quote
Old 04-21-2005, 11:05 PM   #11 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
rotting rubber, biggest enemy of a cars running condition
old faithful
amerikim is offline   Reply With Quote
Old 04-21-2005, 11:37 PM   #12 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
look in the manual. it will give you the breakdown of what needs to be serviced.
at 160K, if you have not done anything like the water pump, belt, tranny drain/flush, spark plugs, replace rubber parts (strut mount)... then it's good to do it ASAP. time to save up also.. it will cost you about 400-600 if you do it yourself. Dealership will run you 1k easily.
ie. look at the pic below for the 60K service. just a rough idea.
skewe is offline   Reply With Quote
