Black coating in Halogen - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-21-2005, 06:14 PM   #1 (permalink)
View CX889's Photo Gallery
While I was looking at the lights in my camry I notice there is a black coating. Why is there a black coating on the tip of the halogen lights (H4)? Can it be removed in any chance? Thanks!
2010 Venza V6 AWD / Magnetic Grey Metallic / Navi and JBL Package
CX889 is offline   Reply With Quote
Old 04-21-2005, 06:38 PM   #2 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
that is like to reduce the amount of light projected from the tip of the bulb... i think there is a different kind of H light that has no covering on it... hope this helps
BlueFusion
BlueFusion6851 is offline   Reply With Quote
Old 04-21-2005, 06:48 PM   #3 (permalink)
BlueFusion
Thanks for your info but can I remove the coating?
Old 04-21-2005, 09:54 PM   #4 (permalink)
3VZ-FE Camry
View sanengo's Photo Gallery
It's supposed to be there. Light from your headlights is reflected mainly, so that coating on the tip shouldn't affect anything.
3VZ-FE Camry | 3MZ-FE Solara
sanengo is offline   Reply With Quote
Old 04-22-2005, 12:44 AM   #5 (permalink)
So even if I scrape it off it will have no effect?
Old 04-22-2005, 09:30 AM   #6 (permalink)
Any response??
Old 04-22-2005, 03:02 PM   #7 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
thats the 9006 bulb (low beam), you can mod a 9005 (high beam) bulb to fit the 9006 socket. Its actually a quite effective mod. Check the CamryFAQ under "MORE LIGHT" for DIY instructions
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 04-25-2005, 02:56 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Do not remove the black coating, because in doing so you probabbly will damage the bulb surface, and may cause it to crack while in use. Anytime you get a bulb, even if new in package, wipe it with an alcohol wipe, to remove any oils too.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 04-25-2005, 05:19 PM   #9 (permalink)
jackfrost1031's Avatar
View jackfrost1031's Photo Gallery
agreed, you'll probably scratch the bulb surface, thus weaking it. You'll probalby blow the bulb between the oil and scratches pretty quickly. Get some alchohol swabs and just handle the bulb by it's base.
1996 T100 2wd 5vz-fe
jackfrost1031 is offline   Reply With Quote
