Shocks..Tires Rubbing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2005, 01:47 AM   #1 (permalink)
View cnl83's Photo Gallery
I bought my car about two years ago. Its a 1998 with a V6. I noticed that when I have passengers my tires rub the fendor. I have 15 inch rims that came with the car. Im not sure if the tire size is correct, but other cars I seen like mine have the same tire measurements. I also noticed that most camrys SAG in the back. Im wondering if anyone else had this issue. If so what did you do about it. Im going to have the shocks changed, but im also wondering about springs???? any thoughts would help.
Thanks in advanced
cnl83 is offline   Reply With Quote
Old 04-22-2005, 07:57 AM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
Thanks in advanced
most camry's sag...this is true. You also have to look at it as you have more weight in the back and focus it on the rear...which would do this. if you have the stock size tires...you shouldn't have a problem...solution would be to upgrade the suspension and diffrent rim and tire....kinda major mod for a daily driver
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 04-22-2005, 10:20 AM   #3 (permalink)
Surely there is some shock or spring I can get without changing my rims...I like the ones I got.
Old 04-22-2005, 10:29 AM   #4 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
there is always spacers that will help prevent rubbing.
check out pepboys as they carry it. Autozone does not.
skewe is offline   Reply With Quote
