When to change Timing Belt ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-22-2005, 07:48 AM   #1 (permalink)
yota=good
View Morley's Photo Gallery
4th Generation When to change Timing Belt ?
I just bought a 2000 XLE V6, with 88,300kms on it.
The dealer told me that it does not need to be changed until 150,000kms..
Having just recently snapped my timing belt on my Honda Prelude, I know that it is
a very costly repair due to the fact that these are interference engines.
Now I wanted to know from owners here, if anyone has had a timing belt snap on them,
and how many kms was it at?
How often should I change this belt?
Thank you kindly,
Morley
Morley is offline   Reply With Quote
Old 04-22-2005, 07:52 AM   #2 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
I would check if it was changed before...I do mine at 70,000 miles....religiously
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 04-22-2005, 07:53 AM   #3 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
no you have a non-interferance engine you can snap it and it wount kill it self.
i belive the 97+ engines were 90k miles .... so your right 150k kms
^ and leaving it that way!
Old 04-23-2005, 01:11 AM   #4 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
I bought my Cam used and of course dealer told me everything was done. Bullshitz. However I use the belts I can see as a guideline, If I start seeing cracks (3 per inch) in the belts, I would change them all out including the timing,
old faithful
amerikim is offline   Reply With Quote
Old 04-23-2005, 02:57 AM   #5 (permalink)
View 500KCamry's Photo Gallery
Morley,
I do mine every 100K km or 60 mi, to avoid towing and retiming due to the belt breaking.
My first 2SE belt went to 180K km before breaking, my first 5SFE belt broke at 137K km. Both broke 100Km out of the nearest town and towing was costly. Both the 2SE and 5SFE are on their fifth belt. I haven't changed my 1MZE belt yet.
Two things you should consider are the low temperature during winter, -30C and even -40Cor -45C, can take some km off the life of a belt.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 04-23-2005, 03:00 AM   #6 (permalink)
View nadir's Photo Gallery
yeah, just take a look at the belt and see if it's cracked...
otherwise, go with OEM belts and find out how long they last.
My dad's belt was goin bad (94 corolla) at about 160k miles .. not to bad
[ '89 CELICA GT ] ---- [ 5-spd 1996 M A X i M A SE ]
nadir is offline   Reply With Quote
Old 04-23-2005, 09:33 AM   #7 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Check at 60,000m, replace at 90,000m. Convert that and there's your schedule.
Toyota has that schedule for a reason LoL!
This one was changed by Lexus at 60,000m, it split in half at 105,000m on the highway when it hit 143mph after I rebuilt the heads.
This one... Was I think the wrong size (missing a tooth), and it snapped in half in a day or two.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 04-23-2005, 06:28 PM   #8 (permalink)
tC
View 95camguy's Photo Gallery
i do mine every 60-70,000 miles. at $200 its silly not to.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 04-23-2005, 07:47 PM   #9 (permalink)
View 89molavi's Photo Gallery
From what I know the look of the belt doesn't tell you much. They usually fail catastrophically. Now if they look cracked thats something, but if they look "fine" they can still snap same day.
89molavi is offline   Reply With Quote
Old 04-23-2005, 09:47 PM   #10 (permalink)
Carzzz's Avatar
View Carzzz's Photo Gallery
I ask the dealer and it's 6yr/150,000km(93750miles)... they told me that the rubber "ages"
Carzzz is offline   Reply With Quote
Old 04-24-2005, 12:09 AM   #11 (permalink)
View Grayguy's Photo Gallery
wow, I must be really lucky or something, cause I just replaced my cars afew months ago at 160K...
Grayguy is offline   Reply With Quote
Old 04-24-2005, 12:10 AM   #12 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
change around 100-120km dealer says 150km
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 04-24-2005, 10:09 AM   #13 (permalink)
View dj14901's Photo Gallery
Every 60k for me...
DJ
dj14901 is offline   Reply With Quote
Old 04-24-2005, 10:23 AM   #14 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
a v6 would cost you about 300$ to change the timing belt.
4cyl would be around 200$.
check manual, there is a schedule.
gen 4.5 (2000-2001) requires/suggest changing belt at 90k. might be worth while to chnage the water pump.
skewe is offline   Reply With Quote
Old 04-24-2005, 02:32 PM   #15 (permalink)
View ezshift5's Photo Gallery
...one of the best shops in the capital of CA agrees (almost) with the above.....100k and also change out the water pump...........................ez
ezshift5 is offline   Reply With Quote
