Originally Posted by ekim55121
whats that rear plug drain out and should you drain it if your car has like 160k miles?
Fluid for the differential.
Yes, I would do a drain and fill on it if its never been done.
The differential is filled through the backside, where it says filler hole. You need a funnel and some clear hose. Make sure the car is level when you fill up the differential.
You'll know when its full cos the fluid will backup into the hose.
The drain plug/bolt for the differential is also 10mm hex, like the tranny drain plug/bolt.
Fill plug/bolt for the differential is 17mm IIRC.
The differential (A140E tranny) on a 5S-FE holds about 1.5 quarts of fluid.
Originally Posted by 92camryguy04
oh yea how much quarts is it? i plan to take off the bolt and drain it, then fill it from the dipstick holder on the top.
It takes a few quarts. 3 - 4?
You'll only get a few quarts out. The torque converter will still have fluid in it.
Yes, you drain the tranny by removing the bolt. And fill it backup through the dipstick.
P.S. I edited the pic above.
The tranny and differential is filled and drained seperately. This applies to automatic trannies.
Tranny: Drained through the tranny drain plug/bolt. Filled through the tranny dipstick.
Differential: Drained through the differential drain plug/bolt. Filled through the backside of the differential (fill hole/plug/bolt).
