KYB/Tein - bottoming out? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-24-2005, 09:20 PM   #1 (permalink)
surfCam
View surfcam's Photo Gallery
4th Generation KYB/Tein - bottoming out?
I know several members have this setup, so I'm wondering if any of you guys have issues with your struts bottoming out when you hit a moderate(not big) bump like at a bridge or something...mine keeps doing this so I'm wondering if I've got a messed up strut or if this is regular.
Also, I'm not talking about speeding over speed bumps, just regular driving when I'm having this problem. One of my buddies said he had bump stops installed with his struts to prevent that...any ideas?
1997 Camry LE i4
K&N drop in filter
Aerospeed strut bar
KYB Struts
surfcam is offline   Reply With Quote
Old 04-24-2005, 09:44 PM   #2 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
You didn't take the bumpstop out completely did you? You're supposed to trim it some but not all the way.
I didn't trim my bumpstop at all. I'm on OEM struts and I don't bottom out...
CDub LXi is offline   Reply With Quote
Old 04-25-2005, 08:34 AM   #3 (permalink)
surfCam
well, I didn't do the install myself...and i'm not too sharp on that stuff...do the original struts have bump stops on them to begin with?
I had a shop that's been doing my tires for years do the work, so I'm assuming that they removed the old bump stops with the old struts...guess I'm going to be going back to them to have this fixed...
1997 Camry LE i4
K&N drop in filter
Aerospeed strut bar
KYB Struts
Old 04-25-2005, 11:47 AM   #4 (permalink)
tC
View 95camguy's Photo Gallery
i dont think new struts come with new bumpstops, i think u reuse the old ones. either way check and make sure you got 'em.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 04-25-2005, 12:36 PM   #5 (permalink)
CDub LXi's Avatar
You reuse the stock bumpstops. If you don't have them it can cause your strut to bottom out and cause premature wear of the strut.
It's easy to see if you have them. Just jack the car up and look. It'll be a piece of rubber about 3-6" tall that goes on the shaft of the strut. To trim you can use a kitchen knife but like I said.. with the small drop Teins provide I didn't do mine. If you have the rubber dust boot (I removed mine) you might have to move it some to see if the bumpstop is there.
Old 04-25-2005, 12:41 PM   #6 (permalink)
surfCam
okay, i'll check that out to be sure. I did call my shop and they said there was not a bumpstop on the old struts, so they probably threw them out ...any idea where I can pick up replacements?
1997 Camry LE i4
K&N drop in filter
Aerospeed strut bar
KYB Struts
Old 04-25-2005, 12:51 PM   #7 (permalink)
CDub LXi's Avatar
Junkyard (not worth the trouble if you ask me), ebay (maybe) or Toyota dealership
edit:
I reused my dust boot too.
