Are my bearings going? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2005, 11:58 AM   #1 (permalink)
Alpha Noob
SupraMan7M-GTE's Avatar
View SupraMan7M-GTE's Photo Gallery
2nd Generation Are my bearings going?
I have a very annoying noise in my Camry. It's a buzzing sound, like something rubbing. It only does it when I turn the steering wheel past center to the right. As soon as I go back across center to the left, it sounds fine. I looked for a week to find something rubbing in the well, or underneath, but found nothing. I put the car on stands. and the noise was not there, so it only does it under load. My friend told me my wheel bearing was going out. Wouldn't it makes noise both directions if it was the bearing? Forgive me for my ignorance, lol. BTW it's a 1990 Dx 5-spd. Any advice as to what to look for would be greatly appreciated. Or a link or reference to a troubleshooting guide would be great. I'm starting to think my Chilton is worthless for troubleshooting. The noise also gets louder the faster I go. It's not really noticeable until I hit 40+ mph, then it get loud. This noise is going to drive me mad, and I refuse to pay some guy $150 that only works on GM cars, to tell me what it is, then charge me $500 more to fix it. Thanks everyone for you time. :
Nothingness cannot be defined; The softest thing cannot be snapped
SupraMan7M-GTE is offline   Reply With Quote
Old 04-26-2005, 12:10 PM   #2 (permalink)
MCH Engineer in training
Location: A-town, Doylestown, & Northampton, PA; Morgantown, WV (WVU COE)
View ag6286's Photo Gallery
Check out ur CV joints, inner and outer, both sides. If the boots are torn then the rubbing/squealing is probably that, and most likely you will have to replace it because there is too much dirt in the system by now...be careful they can break after awhile...ive never heard of that happening but im positive its possible. If you have experience and can take apart and clean which ever joint it may be do that and save some money otherwise you should replace immediately.
ag6286 is offline   Reply With Quote
Old 04-26-2005, 05:28 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
get the wheels off the ground and grab each one at 12;0 and 6;00 and see if it is at all loose
Old 04-26-2005, 07:03 PM   #4 (permalink)
View karazy's Photo Gallery
Your friend is probably correct. Bad bearings will start making noise when cornering because there is more of a load on them at this time. If it only makes noise in one direction, then only one side is gone.
karazy is offline   Reply With Quote
Old 04-26-2005, 08:48 PM   #5 (permalink)
Livers are for wusses
nobrainer's Avatar
View nobrainer's Photo Gallery
is it a clicking? clicking usually occurs if the axles are worn out..
you will most likely hear clicking when you turn...
nobrainer is offline   Reply With Quote
Old 04-28-2005, 03:07 PM   #6 (permalink)
Alpha Noob
No clicking, my celica had bad CV's that clicked. This is mainly a buzzing sound. The CV boots are in good shape from what I can tell. Everything's tight. Could it be my power steering pump at all? A friend said his made horrible buzzing noise when it started going out on him. Thanks for the advice all :
