5S-FE heads - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-26-2005, 09:32 PM   #1 (permalink)
View Spareprtsracing's Photo Gallery
5S-FE heads
are the heads from ALL 5S-FE interchangable? Is there a differnce between the ones on Camry and MR2? Thanks.
Spareprtsracing is offline   Reply With Quote
Old 04-27-2005, 03:43 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Not sure about the cylinder head on a MR2.
There is a difference in the cylinder head on a Camry depending on the year. The oil and water passages changed.
The later (97+) 5S-FEs on a Camry don't have a distributor.
"Skoolin' the unlearned!"
Old 04-27-2005, 04:15 PM   #3 (permalink)
Boss Honky
YESCA's Avatar
iTrader Score: 29 reviews
View YESCA's Photo Gallery
The 5SFE is the same. Headers from a MR2 will bolt up to the camry but the problem you will run into is the down pipe. It bends the complete opposite way than the camry, you will have to buy a down pipe or have one custom made.
OG Team HAMSTER
O.G. Team HAMSTER violated my mom for food stamps
OHIO FORCE!!!
YESCA is offline   Reply With Quote
Old 04-27-2005, 04:30 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
^ He's asking about a cylinder head, not a header.
Old 04-27-2005, 08:11 PM   #5 (permalink)
Boss Honky
YESCA's Avatar
^^^ Your right my bad....I did not read the post carefully....
In that case I would have to say it might not work.
OG Team HAMSTER
OHIO FORCE!!!
Old 04-28-2005, 08:27 PM   #6 (permalink)
ok... not sure what year this camry engine is and not sure how to find out. any suggestions? the block is toast.. the head is fine... have 91 mr2... and this spare engine from a camry... paid $50 for it... many parts are still usable... am thinking to port and polish maybe even shave the head IF it will fit the 2... but only if it will fit. so anysuggestions again on how to determine when this camry engine was produced? thanks again!!
Old 04-28-2005, 08:28 PM   #7 (permalink)
oh... and i am a she... not a he...
Old 04-28-2005, 11:06 PM   #8 (permalink)
Boss Honky
YESCA's Avatar
^^^^ Good to see another girl on the fourm....Welcome to TN and don't let some of these guys get to you. Ask away..........Use the search function first
OG Team HAMSTER
OHIO FORCE!!!
