ABS or bad rotors? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-27-2005, 12:33 AM   #1 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
4th Generation ABS or bad rotors?
Recently I installed new brake pads and cross-drilled rotors. However, sometimes when i brake softly it feels like it slows down and brake in stages. as if i were pumping the brake pedal. I dont think it is ABS because my tires arent slipping, its at low speeds and the braking intervals are much slower than the ABS. so what could this be?? could it be bad rotors bad brake pads, or they both are not compatiable or ABS???
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 04-27-2005, 08:06 PM   #2 (permalink)
Camry Freak
98CamryLE's Avatar
View 98CamryLE's Photo Gallery
I'm guessing it's not the ABS. You know when ABS is working- you can feel the very quick pulsating of the brake petal, and if you turn the radio off and close the windows, you should hear the sound- kind of quiet electronic whine. If there was a specific problem with the ABS, the light would be on. So that probably means that it's the pads or rotors you installed.
I'd take the tires off and check to make sure things look okay. maybe one of the pads is sticking, or you could simply have a bad pad or caliper (sp). Or take it back to the shop that installed it.
Either way, I'd make sure your brakes are working 100%, even if it means spending some money at a shop to make sure.... you don't want to screw with brakes.
2007 Camry Hybrid
98CamryLE is offline   Reply With Quote
Old 04-27-2005, 10:27 PM   #3 (permalink)
View joandjo's Photo Gallery
Yeah. What kind of pad did you use? The pad backing plate might be off... Do not use cheap pads...
1992 Toyota Camry LE, 3vz-fe, 254K mi, still going strong...
joandjo is offline   Reply With Quote
Old 04-28-2005, 06:25 AM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Im not a fan of the cross drilled rotors either. Have seen too many of them crack.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 04-28-2005, 02:10 PM   #5 (permalink)
-= CAMRY =-
yea i know what you mean i just got them for fun and to see if it actually help braking but it sure looks good with rimz tho.!
