Who will be the first to turbo a 3vz-fe??? - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 04-27-2005, 07:45 PM   #1 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool Who will be the first to turbo a 3vz-fe???
Well what some of us have known for over a month that it was Sean McElligott!
http://www.turbotoyota.com/turbolextour.avi
http://www.turbotoyota.com/turbolex.avi
Video from two weeks ago. GM-8 Spools 5.88psi at 3500rpm. 4000rpm it takes off. Because the 315cc injectors are way under-sized for that fairly... Well endowed turbo, you can see it lean out horribly by 4500rpm.
Car's being taken apart for ceramic coating, and a few misc part upgrades (Intercooler change, BACK to new 550cc injectors, new engine management) later on and *should* be back on the road with a 15psi spring early - mid summer.
CGT's to MCE for beating everybody else to the punch!
Car information can be found HERE, but be forewarned. The information is not 100% up to date as things change. (Such as MCE has never used an S-AFC... Stock ECU controls fueling right now)
AIM/Yahoo Toysrme257th
Now with Turbo!
Toysrme is offline
Old 04-27-2005, 07:50 PM   #2 (permalink)
View mcelligott's Photo Gallery
Yea i really need to update that mods list. I'll have some real videos in the upcoming weeks, when im giving it full throttle and not just playing around to see if the car runs lol. Thanks for posting that Brandon!
Turbo 3vz-fe with Nitrous...you have questions? I have answers, Get a hold of me on aim!
mcelligott is offline
Old 04-27-2005, 07:56 PM   #3 (permalink)
Me and my Bebe, Bianca
CamryPunk's Avatar
View CamryPunk's Photo Gallery
I thought toyota has been turboing the 3vz in their trucks for racing for some time now.
Yukio Taira
-1992 4 door Bomex'ed out, Nitrous Express Sport'n, Rippmods SuperCharged Camry
-1992 4 Door EX Honda Civic 5 spd.
-2002 Subaru WRX Wagon... full JDM goodies. My new show car.
CamryPunk is offline
Old 04-27-2005, 08:13 PM   #4 (permalink)
Yea that motor is different from the 3vz-fe -- you would be thinkgin of the 3vz-e i believe.
Old 04-27-2005, 11:35 PM   #5 (permalink)
engineer in training
Gameroom cash: $145055
err, there has been a turbo 3vz-fe camry for a cople of years now, but his setup kinda sucked so that doesnt count
Luckynumber5 is offline
Old 04-27-2005, 11:47 PM   #6 (permalink)
3VZ-FE Camry
View sanengo's Photo Gallery
AFM in your Turbo intake line?! I suppose you are using a custom MAF sensor on the intake connected to your phelum?
If all goes well, I'll turbo up after Brandon. I suppose a "small" turbonetics will do . I want to see that future diesel turbo of yours.
3VZ-FE Camry | 3MZ-FE Solara
sanengo is offline
Old 04-28-2005, 12:11 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The AFM is placed on the turbo compressor inlet. It operates (draw through mode) just like stock.
My turbo 3S-FE was setup like that.
"Skoolin' the unlearned!"
88 LE is offline
Old 04-28-2005, 12:49 AM   #8 (permalink)
3VZ-FE Camry
Does it require some sort of adjustment to the ECU? Because, the turbo sucks in plenty more air than stock, may cause premature wide opening of the flap.
sanengo is offline
Old 04-28-2005, 01:14 AM   #9 (permalink)
I has boost..!
Razo-E's Avatar
View Razo-E's Photo Gallery
that one guy in Florida..?
well, this can be the 1st turbo ES300 with a 3VZ..
1986.5 5-speed '91 7MGE
1989 5-speed TURBO Targa (NA->7MGTE) BPU and lots of rare/JDM/Euro stuff
1992 5-speed hardtop - 2JZ-GE
2005 Scion xB - no longer stock
Razo-E is offline
Old 04-28-2005, 09:01 AM   #10 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285280
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
well, though not the 1st to turbo, I may be the 1st witht he venom setup in a camry.....I'm still cannon fodder for the most part
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is online now
Old 04-28-2005, 02:47 PM   #11 (permalink)
Toysrme's Avatar
Cool
No custom MAF's for 3vz-fe's for two reasons:
1) The 3vz-fe all ready has the largest AFM (air-flow meter = vane-flap) Toyota ever used in a car (including old i6 turbo's)
2) The 3vz-fe AFM uses a backwards scale... Instead of 0v being idle, and running up to around 5v as airflow increases; the AFM runs 5-0v. Specifically, it starts around 4.5v, and idles between 4.2-4.5v. Wide Open Throttle / high rpm / airflow on the stock engine lowers to around 1.5v.
Because of the fact that the stock 3vz-fe will all ready OUT FLOW nearly every hot-wire MAF Toyota has ever used, and the fact that this is the only known 5-0v scale that I've researched in *any* Toyota (I've talked to many part dealers). There is no reason to swap parts for all, but the highest horsepower engines.
The stock AFM should be fairly accurate until at-least 400hp with of airflow. Even when you pass it's normal limit, you can simply by-pass the stock AFM. By that I mean give the air TWO paths to travel, then simply use a piggyback to re-adjust it.
The problem comes in when you keep adding airflow and you hit the minium voltage. Around 0.4 volts. Even if you swapp, and calibrate a different air meter, what exactly happens???
You can't swing a negative voltage on this scale, and there-hence-forth I *HIGHLY* doubt Toyota did any ECU programming when the AFM voltage hits 0v! LoL!!!
Now with Turbo!
Toysrme is offline
Old 04-28-2005, 03:00 PM   #12 (permalink)
Always Under Construction
View whocares04's Photo Gallery
congrats mcelligott! now go burn some ricers! i would love to see they're face as u fly by them with the PSSSSSSSSSSSST!!
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline
Old 04-28-2005, 03:21 PM   #13 (permalink)
Toysrme's Avatar
Cool
Well considering he use to do it with 240-250hp n/a, with a 120 to 150 spray of juice on top of that... It's nothing new for him!
The *best* part about sean having the fastest ES/Windom/Camry/Vista I've actually seen run, (nothing against Justin or Tony, Justin aint re-built yet, and Tony is simply having that last 10% filled with problems, on a 90% done beastly project.)
Sean is tied for the SLOWEST of all his car group. Even if you're tied with a Mustang for being the slowest of the group, the 800hp+ Viper is good company to be in, bawahahahahahaha!
Now with Turbo!
Toysrme is offline
Old 08-03-2005, 07:48 PM   #14 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
Wink
I haven't been on for a while and ran across this while doing a search...
Sorry Toysrme, hate to correct you because I'll always be the first to give props to Sean for his endeavors, but there's been a running 3VZ Camry turbo in Melborne, FL since early 2003:
http://www.geocities.com/tvswitch200...?1049479943526
While on Florida in 2003 for a family wedding, I met the two brothers who built it.
They were more than happy to invite me over and check it out...
Garret T3 running 10psi with stock internals on an automatic tranny, using a Greddy E-Manage that they wired on their own.
It was running when I saw it, so as far as I'm concerned, it does count.
Even with that being said, definite props to you Sean...
Keep pushing Man...I always look forward to any updates...
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline
Old 08-03-2005, 10:28 PM   #15 (permalink)
Knailgun's Avatar
good post, old thread revival...but most importantly...your talking to no one...Toysrme was banned again
Closed Thread
