Camry pulling to the right on highway - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-29-2005, 08:15 PM   #1 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
4th Generation Camry pulling to the right on highway
2000 LE 4cyl. 81000miles.
tires/rims are relatively new. About 10K on Michellin MXV4 plus.
Anyway, I was on a highway and i noticed that my car pulled to the right a bit. If i travelled over 200-300yrds without holding the steering wheel, my right wheel will be touching the white dividing lines of the highway.
Prior to that, I could just not hold the steering wheel and it could go in a straight line. Did not drive my car for the past 2 weeks..
Checked the tires and rims, everything seems OK. After checking the tires at the rest area, tire pressure of the right tires were 1 psi less than the right tires but that should not have caused the car to pull to the right.
I am a bit concerned. Is it the alignment???
Thx
skewe is offline   Reply With Quote
Old 04-29-2005, 08:24 PM   #2 (permalink)
View camlex's Photo Gallery
I don't know the technical word but in toyota that adjestment is not available, even you do allignment.
but switch front right to front left,and front left to front right. that will resolve the problem.
Hope this help.
camlex is offline   Reply With Quote
Old 04-29-2005, 08:26 PM   #3 (permalink)
cam2Xrunner's Avatar
Hope this help.
Yup, it's called Caster. You can only adjust the Toe and Camber(if you have the bolts)
You might have a radial pull, try switching the left and right front tires. That might fix it or make it pull left.
If you can't get rid of the problem, throw a few psi in that right front tire
Old 04-29-2005, 08:36 PM   #4 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
same thing happened to me in the Wraith ... I had to replace the a-arm to fixed the problem...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 04-29-2005, 08:40 PM   #5 (permalink)
skewe's Avatar
how much is it to replace the a-arm
is there a quick and less expensive fix?
Old 04-29-2005, 08:42 PM   #6 (permalink)
skewe's Avatar
i might want to rotate my tires tomorrow. it's about time.
Old 04-29-2005, 09:14 PM   #7 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I have that caster problem. My frame is bent so I'm used to mine pulling to the side.
http://www.xclusive.bz
Old 04-29-2005, 09:17 PM   #8 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
retail I think was $280 or $380 something like that .... I have preffered customer pricing at my regular toyota dealership sooo I didnt pay much ...
MySpace:
Old 04-29-2005, 09:31 PM   #9 (permalink)
View tightcamry129's Photo Gallery
what's an a-arm?
tightcamry129 is offline   Reply With Quote
Old 04-29-2005, 11:21 PM   #10 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
same as a control arm, it runs from the bottom of the front strut to the body
Old 04-30-2005, 12:27 AM   #11 (permalink)
View karugs's Photo Gallery
By any chance did you hit anything recently? Perhaps hard braking or gravel? I would think a big jolt would cause the A-arm to bend...you will remember it if any.
karugs is offline   Reply With Quote
Old 04-30-2005, 01:59 AM   #12 (permalink)
-= CAMRY =-
View pk_kk's Photo Gallery
toyotas have fairly good alignment. i think you should balance and rotate ur tires.
http://www.cardomain.com/id/pk_kk
pk_kk is offline   Reply With Quote
Old 04-30-2005, 07:37 AM   #13 (permalink)
Carzzz's Avatar
View Carzzz's Photo Gallery
4th Generation
A Camry gen 4 pulls to the right, too. And did gave a few extra psi to the right front. It is better on take off (does not pull to right as much) and could sustain in a straight line a bit longer. The downside of this is the steering wheel vibrate at high speed, and hopefully it will not affect on sudden braking. BTW, earlier model of gen4 do suffer from the struts problem
Carzzz is offline   Reply With Quote
Old 04-30-2005, 08:52 AM   #14 (permalink)
skewe's Avatar
4th Generation
did not drive the car for a quite some time.
I did not hit anything or did any hard braking.
any idea how this happened besides hitting something or braking.
Old 04-30-2005, 08:56 AM   #15 (permalink)
Seem.2.Attract.5Ohhz.Alot
totalreborn's Avatar
View totalreborn's Photo Gallery
it could have just been the wind....strong winds usually push cars to the side when going maybe over 60...drive the car now see if anything changed
.::T:0:t:a:l: === R:e:b:0:r:n::.
totalreborn is offline   Reply With Quote
