Originally Posted by touringcamry
I will also replace the differential fluid. However, the fill hole is on the back of the differential facing the rear. How do I fill this after I drain it? Do I get a piece of hose and a funnel and fill it from the top?
Yup, use a piece of clear hose and a funnel.
Make sure the car is level when you fill the differential, otherwise it won't fill completely.
I have 5 qt of Dex III fluid, will this suffice for what I plan to do?
Might want to pick up another 1 - 2 quarts.
The differential holds about 1 1/2 quarts. And the tranny holds 3 - 4 quarts (drain and fill).
Will 2001 Solara V6 TRD Strut bar fit on my 2000 Camry 4 banger?
Yes.
