Help, Please. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-03-2005, 07:55 PM   #1 (permalink)
View TOYOTA CARS's Photo Gallery
3rd Generation Help, Please.
So it rained heavily yesterday and I start the Camry to warm it up this morning. I go back inside and when I come back out the first thing I noticed was the exhaust coming out in quick intervals. Ok... I then see my car physically vibrating with the water beads on the car moving back and forth.
This was not good. I pop the hood open and I see my engine literally bouncing up and down very quickly.
The first thing that came to mind was my engine cracked which led to water seeping in and causing a vibration when the car started. I tried to go for a drive and when I started acclerating, it felt the tranny was failing and the car vibrated the worse @ 1400 RPM. At 2000 RPM it stopped but as soon as it came down, the ugly vibration. I immediately went back towards my house and told my wife not to drive it. I hitched a ride with the wife and kids while they were on there way to school and was dropped off at the train station
What could be the problem? I can't believe a Toyota engine has major engine issues @ 74,000 miles of its life. 10 years old though
I took a test drive and after driving about 5 miles it was gone. My exhaust dripped what seemed to be water and spewed white smoke.
My wife and I are contemplating if we should just get rid of it and get a new car. Currently as of 8:55PM EST, there are none of the vibrations as noted this morning.
1995 Camry LE I4 w/ ~74,000 miles ~ it's dying
2004 Sienna Limited w/ DVD~ Pure Luxury
TOYOTA CARS is offline   Reply With Quote
Old 05-03-2005, 08:09 PM   #2 (permalink)
Always Under Construction
View whocares04's Photo Gallery
y not take it to a mechanic instead of just flat out getting rid of it?
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 05-03-2005, 08:27 PM   #3 (permalink)
There's a lot more other problems that need to be addressed and we're somewhat financially trapped and we want to see if it's worth fixing or would it be more economical to buy a new one.
I had $2000 worth of fix put into the car last time and I can't see me putting another $2K only to have something else break later.
Old 05-03-2005, 08:40 PM   #4 (permalink)
asscarracer's Avatar
View asscarracer's Photo Gallery
Maybe just have a mechanic inspect it for a few bucks, get some estimates and then take it from there
1993 Camry LE w/ 104xxx mi
Python Remote Start/Entry, Low-Beam Silverstars, Ceramic Pads, Double Tipped Platinum Plugs
asscarracer is offline   Reply With Quote
Old 05-03-2005, 08:56 PM   #5 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
It kinda sounds like you might just have bad spark plug wires. Bad plug wires tend to arc or short out when theres a lot of moisture in the air, like after a big rain storm. The smoke you saw was probably unburnt fuel getting cooked off after the catalytic converter warmed up. While its running normally try spraying the wires with a little bit of water, like from a spray bottle. If it starts running like crap right after you spray it then its definatly the plug wires. Thats my guess anyway. Let us know what you find.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 06-06-2005, 10:41 PM   #6 (permalink)
I apologize for not getting back to this earlier. It was not a spark plug or anything that minor. It was a crack in the block. *sad violin plays*
So within 2004 and 2005 I have spent about $4500 renovating this car to optimal peformance again.
Old 06-07-2005, 12:03 AM   #7 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $397185
View RningOnFumes's Photo Gallery
eeesh...that's in the middle of the price range in the kelly blue book 4500
ouch is what i can say.
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is online now   Reply With Quote
Old 06-07-2005, 12:38 AM   #8 (permalink)
View 500KCamry's Photo Gallery
Do you know wjhat caused the block to crack?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 06-07-2005, 05:54 AM   #9 (permalink)
The mechanic said a major change in temperature (like temperature shock?) could have caused it but he's as clueless as I am. I even saw the crack itself. Just this line in the cylinder wall.
Since I need two cars (wife and kids use the Sienna to school, groceries, sports, etc. and I need the Camry for work), I was forced to fix it. Actually, if I wasn't getting a house right now, I might get rid of it. For a Toyota, this is not what I wanted.
Old 06-07-2005, 11:34 AM   #10 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Sad story. How come the crack went un-noticed? There were signs.
Good luck.
mandyfig is offline   Reply With Quote
Old 06-07-2005, 11:40 AM   #11 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285280
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
fuckin tragic.....sorry to hear this....though you should consider an ATK for replacement
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
