need help... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-05-2005, 02:26 AM   #1 (permalink)
View T3vzGfeF's Photo Gallery
need help...
well my check engine light went on...
and i did a diagnostic test on it...and the codes that showed up are
24 = intake aire temperature
31 = air flow meter/map sensor
52 & 55 = knock control signal
by the way my car is a 1993 v6xle 3vz-fe engine....
well anyways...i took out the harness connector from the air flow meter/map sensor-inside the connector everything was bad...the connectors were like broken apart...and i put it back in..and i tried starting my car and it starts but then a 1second later, it dies...
should i replace the air flow meter/map sensor?...
i went to my mechanic...and i asked for a estimate price, which comes out to be more then 450$...im like damn thats too much...i will not be paying that much for parts and labor...and i thought that i'd do it myself...
what is a price for a remanufactured air flow meter/map sensor?
also here where im from...i have not yet seen any camrys in any junkyard thats here, which really sucks...and plus i dont plan on using a used one...
please help,
thanks, peter
T3vzGfeF is offline   Reply With Quote
Old 05-05-2005, 03:43 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Did you remove the connector by removing the 2 screws? If so you screwed up the AFM.
Start looking for another one, unless you can fix the one you have.
"Skoolin' the unlearned!"
