Do you apply your handbrake before you shift it back into Park?? If you don't, then it could be that the transmission is resting on the gear, and obviously, when you try to shift back out into Reverse, it's going to give you a bit more resistance. Try apply the handbrake fully while in Reverse with your foot on the brakes, and then once applied, take your foot off the brake and put the transmission into Park. See if that makes a difference.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
