CV joint? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-06-2005, 10:33 AM   #1 (permalink)
View KevinLi's Photo Gallery
CV joint?
Hi, everyone,
My camry 89's CV joint worn out. It sounds click, click while I am turning.
Since this is a very old car, I am not going to replace this CV joint. My question is:
Is it safe if I do not replace worn out CV joint?
Thanks.
Kevin
Kevin
KevinLi is offline   Reply With Quote
Old 05-06-2005, 10:51 AM   #2 (permalink)
View call831's Photo Gallery
Safety and reliability...
in the rear drive vehicles when the universal joint (CV equavalent) broke, sometimes the vehicles would over turn or cause major under carriage damage. If it happened at 2 AM in the middle of no where then you have to walk. Personally, I have no experience with front CV's breakdown but I have replaced them ASAP when the silly boots break on both my son's Camry and my daughters Acura. Be careful and drive slow if your decision is to drive it to the ground.
JF
call831 is offline   Reply With Quote
Old 05-06-2005, 11:07 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
you can generally get away but remember it is DEFECTABLE. a cv clicking is just worn ball bearings, NOT the actual shaft threads themselves, youre still making pretty much full contact so its fairly safe ^^
terrastrife is offline   Reply With Quote
Old 05-06-2005, 11:34 AM   #4 (permalink)
View 500KCamry's Photo Gallery
Yeah, it's not like a U-joint at all. The five ball bearings give good transfer.
When the wheel is straight, the ball beaings do not move. Only when the wheel is truned do the ball bearings transverse and make the clicking noise.
If the boot is broken, you need to clean, grease and re-boot it. After this if it clicks, which it likely will, you can run it for a long time.
You can help extend its life by not accelerating hard when turning a corner, once the wheel straightens out, then you can accelerate.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 05-06-2005, 01:12 PM   #5 (permalink)
View fj40supraman's Photo Gallery
They can come apart, but I've never seen it. I drove on a clicking one for a yr in my Corolla, till it drove me nuts and I put a new one in for $70. More labor intensive than cost intensive.
fj40supraman is offline   Reply With Quote
Old 05-06-2005, 04:52 PM   #6 (permalink)
89 Camry
View DavesterJr's Photo Gallery
I don't know if the joints are designed any different, but my wife had an escort a while back that the driver side joint clicked for a few months and I never replaced it. It eventually broke in the middle of an intersection and the car wouldn't move, it left her stranded.
DavesterJr is offline   Reply With Quote
Old 05-06-2005, 05:31 PM   #7 (permalink)
Gameroom cash: $304355
Yes, they will eventually come completely apart. You can have the whole axle replaced (cv joint included) with a rebuilt one for around $180 at places like Pep Boys. You can do the work yourself for about half of that, but it is pretty hard work without air tools and without having the car up on a lift; although it still can be done. The decision is your's.
Mike
Old 05-06-2005, 05:57 PM   #8 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
i would change them out, i didnt when the signs came *ominous clicking* and it cost us way more... as in replaced cv boot, cv joint, right driveshaft, change it out if you want to save at least a grand
BlueFusion6851 is offline   Reply With Quote
Old 05-06-2005, 07:17 PM   #9 (permalink)
Always Under Construction
View whocares04's Photo Gallery
my friends old trecel did that for about a month and a half until the wheel just feel off...
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
