OK first things first, stop calling it a MAF. You go ask for a MAF and you'll get the wrong part.
It's an Air-Flow Meter = Vane flap. NOT a hot-wire Mass Air-Flow sensor.
Cut the top of yours open. It'll look like that. There are several things to go wrong.
I'll narrow it down to two things.
1) You shorted, and burned the VC wire in half. This wire supplys 5 volts from the TCCU (ecu) that is metered (so the ECU knows the exact input voltage, and can compair the signals accurately) Obviously the AFM has no power, so nothing works.
2) You've fucked up the fuel pump turn on. This is also housed in the AFM
Before you cut it open, bridge E1 and TE1 in either Diagnostics port, and start cranking. The ECU will then throw codes for intake air tempature (IAT), VS (voltage constant), VS (Voltage signal, THE AFM signal).
If you get no codes, then you need to cut the top off like I said, and see what damage you did.
