I can answer you with a bit more specific since I've done it. There are two ways and
I did the first way (by removing air intake since I need to fix a rear valve cover leak
anyway).
If you do the first way, you need to take off the air intake assembly. In order to
take that off, you need to disconnect around 10 vacuum hosts that are in the way.
It is not hard to disconnect the hoses, but make sure you mark them so that you
can put them back later.
But, you also need to disconnect two coolant running hoses and this requires you to
drain coolant first (then, you need to refill coolant later, use Toyota type!). The whole
process has nothing to do with air contitioning.
The gasket you mentioned is made of metal and I did not change it. It seems to be
fine.
Regarding the second way which does not requires you to remove the air intake, you
need to buy some special sockets. You can search this forum and I remember seeing
it here.
I suggest you buy a Haynes manual and follow it.
Good luck.
Originally Posted by KevinLi
Hi, Everyone,
I am going to replace my rear bank 3 spark plugs of my 1mzfe engine this weekend. I am going to uninstall the intake plenum to make more room for my job. my question is:
Do I have to totally uninstall it? I know there are serveral bolts(maybe 5) on the engine. Also it connects with other side, like vancum, air XXX. I am not sure how to undo those.
Are they air condition related? I want my air condition still working after I reinstall everything back.
Any help would be great appreciate.
Thanks.
