Tires Squeal When Turning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-07-2005, 07:18 PM   #1 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
3rd Generation Tires Squeal When Turning
ok heres my problem... whenever i turn a corner at like 10-15 miles an hour, the outside front tire always squaks just a little... is this from low tire pressure?
BlueFusion
BlueFusion6851 is offline   Reply With Quote
Old 05-07-2005, 07:44 PM   #2 (permalink)
View camlex's Photo Gallery
check air pressure
camlex is offline   Reply With Quote
Old 05-07-2005, 08:17 PM   #3 (permalink)
tC
View 95camguy's Photo Gallery
get some new tires... or some springs and struts. or get all 3.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 05-07-2005, 08:27 PM   #4 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
Yeah. usually low tire pressure
-Chris
TheMajesticking is offline   Reply With Quote
Old 05-08-2005, 01:01 AM   #5 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
that would be tire pressure, you might also want to check your alignment, sounds like you are getting a little too much angle on that tire during a right turn. Other possibilities:
Bad Suspension
Shitty Tires
Just how sharp are you turning anyways?
Applying gas while turning?
Note: By "squeak" i'm assuming you mean spinning/sliding a little, makes like a chirping/squealing noise. correct me if i'm wrong
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
Old 05-08-2005, 07:38 AM   #6 (permalink)
How hard can it be?
^^when it happens most i am in the right turn lane to a divided road.. going maybe 20 miles an hour, without sliding or anything, they just chirp a little bit, and im not turning that tightly.... at least i think so...
BlueFusion
Old 05-08-2005, 10:24 AM   #7 (permalink)
Pulling Out
have you checked the tire pressures yet? what did you find out?
Old 05-08-2005, 10:35 AM   #8 (permalink)
Modifications is Pride.
View ilovecamry's Photo Gallery
I have this kind of problem as well
ilovecamry is offline   Reply With Quote
Old 05-08-2005, 01:35 PM   #9 (permalink)
How hard can it be?
filled all tires to 30 psi cold... i belive this did the trick... so yah... plus now it rides really smooth
ilovecamry- just do what i did, and if it doesnt work, then take S2B Blown 3.5's suggestions into account..
*edit* went driving tonight and they worked great
again, thanks for everyone for your input!
Old 05-08-2005, 02:53 PM   #10 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
I had a similar problem when i bent my front right ball joint.
ECale3 is offline   Reply With Quote
Old 05-10-2005, 03:50 PM   #11 (permalink)
Pulling Out
hmm...30 psi....ok if it works good
What were you running at though? I run mine at around 40 psi... anything lower than 30 is for beach driving lol
Old 05-10-2005, 03:58 PM   #12 (permalink)
How hard can it be?
yea before hand when i checked they were from 24-26 psi... i thought that the portion of the tire touching the ground was too bubbled out too... so i changed it
i still havent noticed anything else going on... so i am taking that as a good thing
