question, was it in drive? cuz if you were driving, as in pulling out of a driveway or something, and it just spontaneously revved to 6k, and you saw a lot of white smoke, then that was probably your tires haha, but other than that check all your gaskets, particulary those around the head and block. that white smoke is something hittin the exhaust manifold/pipe and burning, see where it sprayed on it at and trace back from there. good luck
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
