Nology Wireset - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2005, 11:49 AM   #1 (permalink)
Camryfanatic's Avatar
View Camryfanatic's Photo Gallery
3rd Generation Nology Wireset
Will I see a difference if I use the nology wireset compare to OEM or Bosch? Will it also hurt the engine in the long run? Right now, I have Bosch platium tip plugs (regular) and the bosch wireset, I kinda of did a shitty job of doing my plugs and wires and now I want to redo them. I also notice that theres a unsual idle problem if you use Bosch compared to the regular Desno plugs that were in the car.
Camryfanatic is offline   Reply With Quote
Old 05-08-2005, 12:05 PM   #2 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
It will help the engine in the long run, because better wires means better spark, better spark means more complete fuel ignition, and that means less unburnt/burning fuel going across the exhaust valves and clogging the ports. Also means less buildup on the plugs and cylinders, which helps prevent dead cylinders and detonation/knocking. All in all, better wires are a good thing. Nology are a bit expensive for me, I'd personally rather go with NGK, Bosch are alright but are about the same as stock. Use the stock plugs for the car, that seems to be the best option there. They work fine and deliver plenty of spark for the engine.
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
