Adjust trunk springs DIY - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-08-2005, 05:31 PM   #1 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
4th Generation Adjust trunk springs DIY
Here is a step by step.... but it won't be any good if your spoiler/wing is too heavy.
I am clueless of how to attach the images, so if they are a no show, copy the links please.
EDIT: click below, the album is in sequence.
http://ca.pg.photos.yahoo.com/ph/gal...5d.jpg&.src=ph
Here is my XLE with non functional spoiler:
Here is the torsional arm that will hold up the trunk, push the U shaped section towards the body/outside. Thar will give you some more slack for the following:
Here is a trim removal tool... worth every penny, and a 10mm wrench:
Remove the bolt on the hook with wrench and then use the trim removal tool to take off the hook and trim plug:
Now you should see this:
Make sure you sit inside trunk and make sure it is fully open,
Put your hand on the rod, push up and Pull the rod out and move to the upper slot.
EDIT: Do the same to both sides if a bit more tension is needed, I ended up doing the other for this set of pictures.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 05-08-2005, 06:06 PM   #2 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
none of the pics work.
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 05-08-2005, 11:03 PM   #3 (permalink)
View CX889's Photo Gallery
Is it the same thing for GEN4?
2010 Venza V6 AWD / Magnetic Grey Metallic / Navi and JBL Package
CX889 is offline   Reply With Quote
Old 05-08-2005, 11:09 PM   #4 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
That is a Gen 4...CX889
Great job Hajoca.
Suggestion, you can edit the captions in Yahoo Photos.
old faithful
amerikim is offline   Reply With Quote
Old 05-08-2005, 11:21 PM   #5 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
so you do this to make the trunk sit more flush when you close it?
CDub LXi is offline   Reply With Quote
Old 05-08-2005, 11:39 PM   #6 (permalink)
0111010010
SnakeyeS's Avatar
View SnakeyeS's Photo Gallery
^ Nah. To increase spring tension to help raise your trunk lid if u have a spoiler.
"Knowing is half the battle."
Color Valentine One Displays
SnakeyeS is offline   Reply With Quote
Old 05-08-2005, 11:41 PM   #7 (permalink)
CDub LXi's Avatar
k. I was wondering because my trunk lid doesn't close down like it should I think.. it closes but it looks like it could go down more
Old 05-09-2005, 07:46 AM   #8 (permalink)
Darkside Cut Me!!!
My trunk was popped open for the first picture, it has always done so.... even after the spoiler was put on, and I did not notice any more lift after the increase of spring tension.
But before the trunk lid can close without warning when there is an unexpected breeze. Now it is a definate improvement
2004 RX330 Sport
2003 Cam I4 XLE
Old 05-10-2005, 02:09 PM   #9 (permalink)
Advanced Noob
brungold's Avatar
View brungold's Photo Gallery
nice, thanks
| 1995 Camry LE 5SFE [sold] | 2003 Highlander 1MZFE [sold] | 2006 Tacoma PreRunner 1GRFE [gone] | 2008.5 Audi A3 2.0T [now]
FS: Navone N-85V Line-Out Convertor for connecting amp/sub to Factory HU
brungold is offline   Reply With Quote
Old 05-10-2005, 02:19 PM   #10 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Finally, somebody got to it!
Thank you!
mandyfig is offline   Reply With Quote
Old 05-19-2005, 02:55 PM   #11 (permalink)
Advanced Noob
brungold's Avatar
so i tried to pull out the torsion bar but it wouldnt come out, the 90 degree bend was too long to clear the edge of the hole.
i just read the thread again and saw to "push up" on the rod, just to make sure that means pushing straight up, right?
Old 05-20-2005, 02:58 AM   #12 (permalink)
The Other White Meat
terrastrife's Avatar
just stick a block of wood between teh 2 bars.
terrastrife is offline   Reply With Quote
Old 05-20-2005, 07:42 AM   #13 (permalink)
Darkside Cut Me!!!
First you have to slide the Ushaped section towards the body on the opposite side.
Push up to releive the spring on the slot hole at the 90 deg. bent end and then pull out.
2004 RX330 Sport
2003 Cam I4 XLE
Old 05-20-2005, 08:40 AM   #14 (permalink)
View xxxavier2k3's Photo Gallery
Real good stuff there guys. Tried it on my 3vzfe windom with much success. Thanks
xxxavier2k3 is offline   Reply With Quote
Old 05-20-2005, 11:48 AM   #15 (permalink)
mandyfig's Avatar
Same here, please follow instructions to a T, get in there and be careful, them springs might come undone, that's what happened to me.
But it is so much better now, the Trunk Lid comes up better, and stays up.
Now I am even thing of adding another hole higher to actually add more tension and get more leverage.
Great post OP! Thank you!
