Help with completely draining radiator fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2005, 03:59 PM   #1 (permalink)
I'm Randy
illusive562's Avatar
View illusive562's Photo Gallery
2nd Generation Help with completely draining radiator fluid
hey, i finally decided to drain my raditor fluid because it was a brownish dark color...i drain the radiator like 5 times and even used one of those prestone radiator super cleaner...the water still turns brown everytime i fill...drive awhile and then drain...you guys have any ideas? is that normal? thank you
illusive562 is offline   Reply With Quote
Old 05-09-2005, 04:11 PM   #2 (permalink)
Camry LE V6 2001
View REDSOXTICKET's Photo Gallery
Did you or anyone ever place an additive in the radiator ? I could be that the additive still remains especially if it was the gasket seal additive.
REDSOXTICKET is offline   Reply With Quote
Old 05-10-2005, 01:48 AM   #3 (permalink)
I'm Randy
i ahve no idea if anyone added an additive...it was already brownish black when i got the car...i keep thinking its oil but iono...i drained and fill numerous times...still turns brown when i drive for a couple hours den drain...im just going to take it to a shop and let them flush it...there is a hose connect to the bottom of the radiator the says oil hose...is oil really getting into the radiator?
Old 05-10-2005, 02:17 AM   #4 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
pop the topside radiator hose off at the engine, shove a garden hose in its place, crank the water on and let the water run through the engine till the water comes out clean. If it never comes out clean, that means your radiatior is severly corroded and you should replace it.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 05-10-2005, 02:20 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Yeah, you need to have it flushed to get all the crap out.
I posted some instructions in the thread below:
http://www.toyotanation.com/forum/t44970.html
The 2 small hoses that connect to the bottom of the radiator are for the tranny cooler (built into the radiator).
"Skoolin' the unlearned!"
Old 05-10-2005, 03:04 AM   #6 (permalink)
I'm Randy
2nd Generation
88 le thats the exact method i use...i unplug the drain **** while the engine is running with the heater on and i just let the hose run until i gets clear...but when i turn the hose off the remaining water turns back to the same brownish color...could it be that that oil hose?
Old 05-10-2005, 08:42 AM   #7 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
hmm...I'm going to have to change mines too! It too is brown.
You'll like being blown
Bunthy is offline   Reply With Quote
Old 05-11-2005, 03:16 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
Drain the radiator and look inside of it. Your looking for rust or corrosion.
