Engine Immobilizer..? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2005, 07:42 PM   #1 (permalink)
Camry Gen5er
zettahertz's Avatar
View zettahertz's Photo Gallery
Gen5 Engine Immobilizer..?
Hello,
How can i tell if i have an engine immobilizer in my 2002 Camry LE. or do all Gen5s have it as standard? And no.. i'm not gonna try to somehow hotwire it and see if the engine turns off after a while =P
zettahertz is offline   Reply With Quote
Old 05-09-2005, 07:51 PM   #2 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
iTrader Score: 7 reviews
View xpeed's Photo Gallery
2002-2005 V6 camry LEs and SEs have the immobilizer and they're standard. The XLEs, both V6 and I-4, have them with the anti-theft alarm.
It's only available on the V6s. Not the I-4s.
This is one way to see if you have it or not.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 05-09-2005, 08:04 PM   #3 (permalink)
Camry Gen5er
zettahertz's Avatar
how does it work? is the key chipped?
Old 05-09-2005, 08:05 PM   #4 (permalink)
TN の がしょう
xpeed's Avatar
Yes. Basically the key has a transponder chip. Without it, the car won't start. Now all new toyotas have chips in the key. The one with the immobilizer has a different chip.
Old 05-09-2005, 08:07 PM   #5 (permalink)
Camry Gen5er
zettahertz's Avatar
ic... i'm so dead... cus i just ordered a remote start alarm (Viper 791XV) and i just found out the car has the immobilizer and now i have to shell out another 50 bucks or so.
Old 05-09-2005, 08:18 PM   #6 (permalink)
TN の がしょう
xpeed's Avatar
Heh. Don't depend on what I said. Although this is what I know. If you want to make absolutely sure about it. Go to the dealers and ask the service department. Not the salesrep. Most likely the salesrep will give you a BS assessment.
Old 05-09-2005, 08:27 PM   #7 (permalink)
Camry Gen5er
zettahertz's Avatar
yeah it does seem like it does have immobilizer as standard according to many sites too, just wasn't sure cus i see some w/ packages along with security system. man, the installation places r trying to rip me off by selling the bypass unit for 50 bucks when i see it online for 20-30
Old 05-09-2005, 08:32 PM   #8 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
there should be a flashing red light on the dash, and that light stops flashing when the key is close or in the ignition. The chip in the key sends a signal to the fuel pump, so without it there wont be any fuel
Fresco Bob is offline   Reply With Quote
Old 05-09-2005, 09:07 PM   #9 (permalink)
Camry Gen5er
zettahertz's Avatar
I don't see any blinking lights on my car when i lock it, only got an LE
Old 05-09-2005, 11:51 PM   #10 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
I believe all Gen5's are equipped with them.
- Vince
VVT-i Owns is offline   Reply With Quote
Old 05-09-2005, 11:55 PM   #11 (permalink)
Camry Gen5er
zettahertz's Avatar
somehow when i called toyota dealer, they said they don't have it unless it has the alarm... err weird
Old 05-10-2005, 12:54 AM   #12 (permalink)
View bigdenis's Photo Gallery
My Camry "Azura" (Australia) has the Factory Alarm/Security as standard. i also have a Satellite Tracking System added. On top, I purchased an aftermarket "upgrade" alarm system which piggy backs onto the factory system, thus running off the Camry's own transponder (i.e. also switches alarm on/off) - no extra transponders/FOBs required.
bigdenis is offline   Reply With Quote
Old 05-10-2005, 12:54 AM   #13 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Just something you can check
Look in the owners manual for engine immobilizer in the index or security or something to that effect. I know for my 02 Sienna they actually show pictures of what the stanard non immobilizer key and the immobilizer key looks like. if you are familiar with Toyota keys the old ones have a long slot in the top of the key where you would typically put the key ring. On the immobilizer key the hole for the keyring is more circular and only really big enough for the key ring to fit through. I hope this makes sense this is the best way I can explain it. Oh one other thing the immobilizer key is about 1.5 times thicker than the old standard Toyota key.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 05-10-2005, 07:57 AM   #14 (permalink)
VVT-i Owns's Avatar
You can check it. Go cut a copy of your key. If you have it, it will start then shut off in like 5 seconds. I'm pretty sure they all have it unless those US cars are different.
- Vince
