Oil Drain Plug Gasket - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-09-2005, 08:15 PM   #1 (permalink)
View rickmadison's Photo Gallery
HI all:
While changing oil in my 2002 camry (2AZFE) and found out that it didnt have oil drain plug gasket. I used to have one extra gasket from my 1992 corolla that seemed to fit this plug so I used it for this camry. Now after 24 hrs of changing it, I notice that oil drips, very slowly, underneath pan from oil plug. Was there something wrong I did? Should I drain fully re seal the plug ?
Appreciate your insights folks-
rickmadison is offline   Reply With Quote
Old 05-09-2005, 08:25 PM   #2 (permalink)
View Ken4's Photo Gallery
Tighten the drain plug a little bit more. But not more than 36 ft-lbs. If it doesnt work, buy a new drain plug gasket and try again. If you clean your oil collecting tray very well, you could reuse your oil again.
Ken4 is offline   Reply With Quote
Old 05-09-2005, 09:43 PM   #3 (permalink)
thanks
I tightened it again. But if it drips again, then probably I am gonna just get new gasket and refill the new oil (drain pan is as dirty as it could get).
Old 05-09-2005, 10:43 PM   #4 (permalink)
Man on a mission...
View SKYravefever's Photo Gallery
FYI, The gaskets are about 80 cents from my local dealer.
Time is never wasted when you're wasted all the time.
SKYravefever is offline   Reply With Quote
Old 05-09-2005, 11:22 PM   #5 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
Just get another gasket. You're willing to blow a motor that costs big $$$ for an $.80 gasket?
Edmond.
Edmond is offline   Reply With Quote
Old 05-09-2005, 11:50 PM   #6 (permalink)
VVT-i Owns's Avatar
View VVT-i Owns's Photo Gallery
I'm sure it had a gasket, sometimes it gets stuck on the plug and you gotta get it out.
- Vince
VVT-i Owns is offline   Reply With Quote
