Water in my trunk! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-12-2005, 02:34 PM   #1 (permalink)
View Boostaholic's Photo Gallery
2nd Generation Water in my trunk!
It keeps on coming back. I shop vac it out and it comes back anytime its wet out. The water is mostly in the two outer pockets, usually where you would keep your jack, etc. Any ideas?
Boostaholic is offline   Reply With Quote
Old 05-12-2005, 02:47 PM   #2 (permalink)
Flagrant Fouler
Diehonda's Avatar
View Diehonda's Photo Gallery
How much water? Are your seals cracked or in disrepair on your trunk lid? Are there any holes on the underside allowing water from the tires to get in? I had the same thing but it ended up being a hole by my tires. You might need to gut the trunk and clean it allup and crawl under it while some shines a shop light in the trunk and look for holes. Then use mold and mildew killer to disenfect it.
Free Gen 2 Camry book for anyone coming through Louisville, KY
Diehonda is offline   Reply With Quote
Old 05-13-2005, 03:35 AM   #3 (permalink)
Gameroom cash: $304355
Alternatively, you could crawl in the trunk on a bright shinny day and close the lid. Now look for the light coming through somewhere. It's best to have someone you trust outside the trunk with the keys; someone who is not a pratical joker.
One common area for water to get in is the seals around the tail lights. Have you changed anything or added anything back there recently?
Good luck with the problem.
Mike
Old 05-14-2005, 06:03 AM   #4 (permalink)
89 Camry
View DavesterJr's Photo Gallery
My Camry had water in the outer trunk pockets when I bought it because the trunk latch was loose and the lid wasn't closing tight against the seal.
DavesterJr is offline   Reply With Quote
Old 05-14-2005, 06:07 AM   #5 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
very very very very common problem. i dont know the cause of it, but just about every camry i know has a small or large water problem in the sides of the trunks.
i say just drill a hole in the bottom to drain.
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 05-14-2005, 08:12 PM   #6 (permalink)
Gen 2 Pimp
phat91camryLE's Avatar
View phat91camryLE's Photo Gallery
i had the same problem. Turned out to be the seals around my tail lights. I just used some silicone sealant to fix the problem
4 cyl 1991 Camry LE ... if you own a 2nd Gen Camry talk to me about the modifications you have made or wish to make... lets help eachother out
phat91camryLE is offline   Reply With Quote
Old 05-14-2005, 10:19 PM   #7 (permalink)
View Loan Wolf Cam87's Photo Gallery
yo, on the rearpassanger side of the car remove the back seat shoulder area i think you might have a rust hole above the rear tire
One Monkey Don't Stop No Shiw
Loan Wolf Cam87 is offline   Reply With Quote
Old 05-14-2005, 10:47 PM   #8 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
yea i got the same problem but i think the water is getting inside throw the taillights. i dunno. i got to fix it cuase the water goes unto my amps and thats not good...lol....try to see if the problem is coming from the tailights
lucanhookup is offline   Reply With Quote
Old 05-14-2005, 11:14 PM   #9 (permalink)
Gen2s FTW!!!
knot5000's Avatar
View knot5000's Photo Gallery
yess the taillights, no wonder why everytime i open the trunk, water drops on my head and i have a big rust hole above the rear tire too
knot5000 is offline   Reply With Quote
