Originally Posted by nonfamily_camry
how much do you roll? when do you stop?
Rolling the rears won't help scrub in the front...in fact, the only thing that will help is:
1)Not turning to "lock"
2)Smaller tire (e.g. lower profile, smaller width, smaller height)
3)Rim that is narrow...I think 8" width is about it on a camry
As for the rears, FOR YOU it is especially important that you don't damage the paint. You live where roads are salted.
To help you gauge where your tire is rubbing have about 3-4 people sit in your back seat (that oughta do it
). Run your fingers along the inside edge of your rear fender and see where contact is being made. This is where your efforts should be concentrated. Keep rolling until the MAJORITY of the rub is out (you may not be able to eliminate it--like me).
If you damage your paint you MUST address it. Either have it repainted or go buy some paint that matches your color in a touch up spray and do it yourself. Or you could use a rubberized undercoating since rocks are likely to strike it. Be sure to tape everything off.
BULLMKT
