Turn signal blinks too fast - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-16-2005, 12:53 AM   #1 (permalink)
Astrodonkey's Avatar
View Astrodonkey's Photo Gallery
4th Generation Turn signal blinks too fast
Hi gang,
I've been driving my friend's 1997 V6 Camry LE, and the left turn signal blinks about twice as fast as the right one. At least, it appears this way from the visual indicator and clicking sound in the cabin -- I haven't actually gone outside the car to check if the turn signal itself behaves the same way. I can check if it makes a difference.
Anyway, does anyone have a quick idea as to what could be causing this? Bad relay maybe?
Thanks for any advice!
Astrodonkey is offline   Reply With Quote
Old 05-16-2005, 01:35 AM   #2 (permalink)
Got Gas!
View en1gma's Photo Gallery
Check the indicator bulbs on the left side and you should find that at least one is not working. The indicators blink faster to tell you there is a problem.
If you use the search button, you should find another thread posted today about this problem.
1994 Vienta Touring 3VZ-FE, auto, 280,000 Kms
Dual fuel Petrol / LPG
Stock stock stock stock stock..........
en1gma is offline   Reply With Quote
Old 05-16-2005, 02:48 AM   #3 (permalink)
migoreng's Avatar
View migoreng's Photo Gallery
my 1990 toyota hiace van has the blinker problem..its been like that for over 6 months..
the right blinker blinks fast but the left blinks normal speed...i've checked the right blinkers and they blink. the bulbs aren't dead. i did changed all the indicator bulbs back then...but didn't fix the problem. what could cause it then?
migoreng is offline   Reply With Quote
Old 05-16-2005, 03:44 AM   #4 (permalink)
Got Gas!
Did a bit of searching on the net and found this:
The other problem (rapidly flashing turn signals) is caused by poor electrical contact between the front turn signal bulb and its socket, if the bulb still functions as you indicate.
Remove the bulb from the socket, use a rough rag to wipe off the bulb's contacts and a pencil eraser to gently clean the socket terminals. To get to the bulb, see your owner's manual. This will work temporarily; based on my experience in a 97 Camry with the same turn signals, the problem will return eventually.
You may also want to gently pull up the socket terminals with a pair of tweezers to ensure firmer contact between the bulb and socket.
Maybe give that a try
Old 05-16-2005, 04:28 AM   #5 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $591657
iTrader Score: 7 reviews
View xpeed's Photo Gallery
It's a warning that one of your bulbs are out. Get it checked out.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 05-16-2005, 07:07 AM   #6 (permalink)
View lenjack's Photo Gallery
Not so. It happenned to our 2 98's, and all bulbs were working. Changing the bulbs fixed it.
lenjack is offline   Reply With Quote
Old 05-16-2005, 07:10 AM   #7 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Yeahc check out your bulbs.
http://www.xclusive.bz
Old 05-16-2005, 07:24 AM   #8 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
one of the bulbs are out. (as per mentioned by xspeed)
check it out when the blinker is on
skewe is offline   Reply With Quote
Old 05-16-2005, 07:27 AM   #9 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
One of the bulbs are out OR about to be out. Just because it's working doesn't mean it's not faulty. Take a new bulb and go around and keep switching amongst the bulbs until you find the faulty one.
-Chris
TheMajesticking is offline   Reply With Quote
Old 05-16-2005, 09:16 AM   #10 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $285780
iTrader Score: 40 reviews
View Knailgun's Photo Gallery
check out he bulbs...one is blown...mine used o do that as well
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 05-16-2005, 12:08 PM   #11 (permalink)
Thanks guys, I will check all the bulbs and see if I can find out what's up.
Old 05-16-2005, 12:18 PM   #12 (permalink)
TN の がしょう
xpeed's Avatar
Some bulbs have two wires. one for braking, and other when you turn the lights on. If one of those wires are out, it'll blink fast. So it is a warning that a part of the bulb ain't working right too.
Old 05-16-2005, 02:59 PM   #13 (permalink)
This might be my situation. I checked all the bulbs and they all appear to be working. Maybe I'll try replacing them anyway and see if that fixes the problem.
Old 05-16-2005, 08:23 PM   #14 (permalink)
When our 2 Camrys had the problem, it persisted for over 2 years before I changed the bulb. Front driver's side both times.
Old 05-16-2005, 10:37 PM   #15 (permalink)
camry "durabilty" tester
View brownyy's Photo Gallery
Australia RC constant
the RC constant (resistor capacitor (spelling??)) has changed somehow, thus giving you a fast flash. Had it on my Gen4. However, if all are working, i'm outta ideas for now, but the fast flashing is the change in RC constant.
In blown globes cases, one globe blows, the "R", resistance changes...
enjoy
brownyy
brownyy is offline   Reply With Quote
