Unplug radiator hoses, hard? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2005, 10:50 AM   #1 (permalink)
View ruoknow's Photo Gallery
I am going to repalce the lower radiator support, which was damaged in an accident few monthes ago, since it's move around making some annoying sounds recently.
Is that very hard to unplug the upper and lower radiator hose?
it seems to me that the metal part inside the hose is really long, so it should be very hard to remove.
Do you guys have any trickes doing these?
ruoknow is offline   Reply With Quote
Old 05-17-2005, 10:54 AM   #2 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
just drain the radiator well first, then once it's unclamped, I stick a small flathead inside and pry it off to break the seal it's formed between the metal and rubber and then just start yanking like a mofo. it's not really that hard.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 05-17-2005, 10:59 AM   #3 (permalink)
Nice to know that!
there is a metal pipe inside the radiator for cooling the automatic transmission fluid, so i need to check the ATF level after repalcing everything, right?
Old 05-17-2005, 11:39 AM   #4 (permalink)
Local Rape Machine
View ekim55121's Photo Gallery
yes but you shouldnt loose much
ekim55121 is offline   Reply With Quote
Old 05-17-2005, 02:46 PM   #5 (permalink)
Gameroom cash: $304355
It's easiest to cut the lower hose lengthwise with a utility knife where it goes over the connection on the radiator. Then simply peel the hose off. Pulling hard on the hose can crack the fitting on the radiator.
Mike
Old 05-17-2005, 02:48 PM   #6 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
the transmission cooler lines are the hardest to get off. You have to twist and pull and pry to break the seal on them, it can be a real pain in the ass to get them off.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 05-18-2005, 12:29 AM   #7 (permalink)
The Other White Meat
terrastrife's Avatar
just cut them off and buy new ones... nto expensive.
terrastrife is offline   Reply With Quote
Old 05-18-2005, 01:19 AM   #8 (permalink)
Thanks for your inputs!
Very imformative.
