Amp Spot - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-19-2002, 07:31 PM   #1 (permalink)
View camry2nr2004's Photo Gallery
Amp Spot
I was wondering if there is any way of hollowingout the insie of my backseat, and placing my amps in there. I've seen it done before but im not sure ho thy did it. And they would hve to find some way to reinforce the seats right? if anyone has any info on how they do this, or knows anyone who could help hit me up.
camry2nr2004 is offline   Reply With Quote
Old 08-19-2002, 08:06 PM   #2 (permalink)
EasyE's Avatar
View EasyE's Photo Gallery
hmm... what gen camry do you have? i could prolly rig sumpin for mine... i have a 92 (gen3)
"If Nike gave me the sixty-million they pay Tiger Woods, I'd tattoo their logo to my forehead." -Les Claypool
EasyE is offline   Reply With Quote
Old 08-19-2002, 09:10 PM   #3 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Not a good idea man! Amps generate alot of heat and need air to circulate around it to keep it cool. But if you really wanna do it, it would prolly involve removing some of the foam padding and then building a box that would fit snug in that cavity that you just created, then just drop the amp in the box.
If you go through this site, I'm sure you'll get some ideas as to how to takle this project:
http://www.sounddomain.com/member_pages
Phi is offline   Reply With Quote
Old 08-19-2002, 09:14 PM   #4 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
Yeah, I agree with Phi on that one...insulating an amp isn't good. Most amps need to be positioned a certain way so that the "fins" on the amp can cool itself down sufficiently. They also sell amps that have built in fans in them to cool themselves down.
My amps are mounted to the back of my seats but since they're not too powerful and I don't really crank it anymore, I'm not worried about overheating.
Silver Streak is offline   Reply With Quote
Old 08-19-2002, 09:21 PM   #5 (permalink)
EasyE's Avatar
so wait.... you want to completely cover the amp??? i thought you just meant cutting a whole in the seat and stickin it in there... you know what i mean?
Old 08-19-2002, 09:23 PM   #6 (permalink)
rayray's Avatar
View rayray's Photo Gallery
well... overheating is always concern whenever you surrond your amp with anything. you would need to cut out the material where your amp is to go. and create some sort of backing for the amp to mount on. i would line this backing with some metal flashing so that the amp can conduct heat away. make sure the heatsink has full access to a fresh air source too.
-rayray
rayray is offline   Reply With Quote
Old 08-19-2002, 09:25 PM   #7 (permalink)
EasyE's Avatar
Originally Posted by rayray
well... overheating is always concern whenever you surrond your amp with anything. you would need to cut out the material where your amp is to go. and create some sort of backing for the amp to mount on. i would line this backing with some metal flashing so that the amp can conduct heat away. make sure the haetsink has full access to a frech air source too.
-rayray
yea cut it out, and make sure the built in fan can do its business. my amp is mounted on the back of my box, and when my seats are up i have a problem with overheating sometimes.... but it gets soooo hot down here i dont blame the thing.
Old 08-22-2002, 07:12 PM   #8 (permalink)
aiight thanks guy, i forgot i got the gen 3 camry. i guss ill try to find somewhere else to mount em, anyonegot any idea, thtwould look GOOD, and still be atleast a lil original. how do you do it whe you mount then on the trunk lid? just put the wiring along the trunk hindges? aiight, well thanks anyway
Old 08-22-2002, 07:58 PM   #9 (permalink)
Newbie
smokey8890's Avatar
View smokey8890's Photo Gallery
why not mount it along the side of the wall of the trunk? the amp on the trunk lid might not work as well. its alil too heavy for the lid. phi is right if you want to get some nice idea go to sounddomain.com they got some really crazy installs.
I miss my camry....................
smokey8890 is offline   Reply With Quote
