Slight oil pan leak? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2005, 04:32 PM   #1 (permalink)
Triple A Whore
Edmond's Avatar
View Edmond's Photo Gallery
I noticed that there seems to be some slight weepage around the oil pan area. Is this a common thing? I tightening up the bolts just a tad bit but I didn't take the impact to them.
If it gets worse, how difficult is it to change out the gasket? Is it just a simple unbolt, clean off old gasket, install new gasket with sealer and then bolt back on job?
If it stays as it is now, I don't see a reason to mess with it because it's not noticeable on the dipstick readings.
Edmond.
Edmond is offline   Reply With Quote
Old 05-18-2005, 10:46 PM   #2 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
Don't take the impact to them...I'd use a torque wrench to spec them up. Autozone will lend you one for free.
I personally would fix it. It is a straightforward procedure with RTV sealant on the 1mzfe (the only haynes I have). I'm sure you have a haynes/chiltons...you've been on the boards long enough to know you need one . Consult that first, then conquer.
Good luck.
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 05-18-2005, 11:07 PM   #3 (permalink)
Triple A Whore
Edmond's Avatar
Good luck.
BULLMKT
Oh the impact thing was just a joke. That would be serious overkill for those.
I never even thought about consulting the manual. It just sits in the trunk of the car, I rarely look at it.
In fact, I have a torque wrench, which isn't used much either.
Edmond.
Old 05-19-2005, 12:44 AM   #4 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
If it is weeping, the gasket is bad. It's only going to get worse from there. I'd say replace it/get it replaced soon. The torn gasket could very well because by over-tightening.
Replacing it requires draining all the oil (every last drop), removing the pan, scraping the gasket off the block (if anything is stuck to it), then block sanding the gasket surface, add some sealant and put on the new gasket. Torque it to spec and your good to go
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 05-19-2005, 08:07 AM   #5 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
is it coming from the oil pan
or the oil plug which is leaking on to the oil pan which seems that the oil pan is leaking?
if the oil plug is leaking, just change the plug + washer.
u could do the dye thing to identify the specific area
skewe is offline   Reply With Quote
Old 05-19-2005, 08:11 AM   #6 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I too have a slight oil leak. Nothing major, sometimes it doesn't leak at all.
http://www.xclusive.bz
Old 05-19-2005, 09:17 AM   #7 (permalink)
Moving Forward
View Cyorke's Photo Gallery
are you sure it is coming from the pan and not front seals or rear main seal. if it is at the front of the engine timing belt area could be crank, oil pump or cam seals. Just something else to think about. The oil pan doens thave a gasket if I remember right just black RTV sealant, as BullMarket stated.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 05-19-2005, 10:29 AM   #8 (permalink)
Triple A Whore
Edmond's Avatar
Yeah, it's coming from around the gasket area all around the oil pan.
Edmond.
Old 05-19-2005, 10:50 AM   #9 (permalink)
Moving Forward
one other thing I jsut thought of Dont forget about the oil cooler. I would recommend cleaning it off very good and drive it a little bit jsut to make sure. You would hate to be doing work that isnt needed. Oil leaking from the oil cooler can run down onto the pan and then look as if it is coming from the pan.
Chris
Old 05-19-2005, 12:32 PM   #10 (permalink)
Triple A Whore
Edmond's Avatar
Oh man, I didn't even know I had an oil cooler on the car! I should really read the Haynes manual that I bought for the car!
Edmond.
