shaft play? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-18-2005, 07:33 PM   #1 (permalink)
View asheik9201987's Photo Gallery
4th Generation shaft play?
i wanted to know what shaft play on a turbo means. also if i get a 3s-gte turbo and aftermarket manifold how much will that cost and increase the horse power.
asheik9201987 is offline   Reply With Quote
Old 05-19-2005, 12:44 PM   #2 (permalink)
View gdb1232004's Photo Gallery
Shaft Play means you need to rebuild the turbo homie.
gdb1232004 is offline   Reply With Quote
Old 05-20-2005, 03:00 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
a 3sgte turbo (you mean a ct26?) and manifold will add 0 hp.
terrastrife is offline   Reply With Quote
Old 05-20-2005, 10:37 AM   #4 (permalink)
really? then what exactly do they do?
Old 05-20-2005, 03:15 PM   #5 (permalink)
ok, thanks alot for all your help
Old 05-20-2005, 05:13 PM   #6 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
In a nutshell, how much it "wobbles around". Because turbo's use a fluid bearing they always move a tiny amount. Ifyou can push it back and forth enough so you can feel it... Time to rebuild it.
The more play there is, the closer the compressor/turbine will get to the walls of their respective housings. Eventually they'll scrape it, shaving off compressor/wheel material as it hits (along with the housing).
While that won't out-right destroy the turbocharger, the resulting blanace change will. As it spins, they simply vibrate themselves to pieces.
AIM/Yahoo Toysrme257th
Now with Turbo!
