no?! Than why dose the level on the bayonet change
Because when the engine is running the fluid is being pumped around inside the transmission.
Obviously, you put in what you take out.
Drive around the block, drain the pan & refill. Then do it again so that statistically, the majority of the fluid is drained out.
AIM/Yahoo Toysrme257th
Now with Turbo!
