So I had the same problem after cleaning the throttle body with carbuetor cleaner. I did kinda spray a lot inside the throttle body thoigh, literally took a day and a half of putzing with it and I bought new plugs to get it started. I cleaned the throttle initially because I had a "sticky" pedal on takeoffs, that problem is fixed but now it feels as tho the idle is hiccuping, it never actually dies but more jumps from a steady 850ish to almost a 550rpm.
Any ideas?
I put sum fuel injector cleaner in, no help, no codes either...
How can I test my IAC? Are there any type of setting procedures for it because I did unplug it and unscrewed the two bolts that hold it in place during the no start condition just to look at it, but then i put it right back....could that have done something?
And i did use an autozone brand carb cleaner...
Any help would be appreciated
2000 toyota camry 4cylinder
Nebel777@yahoo.com
