spark plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-23-2005, 09:14 PM   #1 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
spark plugs
hey guys.
I have a question on spark plugs... I've decided to change them in my 95 5S-FE because my currents ones are wearing out. i can actually feel the wire holding it vibrating because of the piston motions and i know thats not good. so anyways, i'm thinking about putting in new plugs.
so my question.... which is better: platinum, iridium, or gold palladium? different brands claim different things and i don't know what to do. I know that nickel is kinda....eh, haha so i'm just narrowing it down to those three.
So yea, does anyone have any actual experience with those plugs? also, should i change my wires too while i'm at it? the car is at 99.5k miles. k, thanks guys!
-alex
95WhiteCamry is offline   Reply With Quote
Old 05-23-2005, 09:40 PM   #2 (permalink)
tC
View 95camguy's Photo Gallery
i really dont know how much of a difference the platinum/iridium etc will make. just stick with NGK or Denso and you will be fine. you can find them online cheap enough.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 05-23-2005, 09:52 PM   #3 (permalink)
Got Gas!
View en1gma's Photo Gallery
Probably worth changing the HT leads as well. If one of them develops a fault, it could take out your nice new sparks as well.
1994 Vienta Touring 3VZ-FE, auto, 280,000 Kms
Dual fuel Petrol / LPG
Stock stock stock stock stock..........
en1gma is offline   Reply With Quote
Old 05-23-2005, 10:32 PM   #4 (permalink)
Still confused...
ok... it may seem odd but it's not clicking into my head right now... what are HT leads? thanks!
Old 05-23-2005, 10:50 PM   #5 (permalink)
Got Gas!
Sorry, High Tension Leads, it's what I've always called them. They are just your spark leads.
Old 05-23-2005, 10:52 PM   #6 (permalink)
Still confused...
oh... i see.... so essentially, it's just the cables connecting the spark plug into the cylinder head then?
sorry, i don't knwo too many terms.. i know what you mean, i think..
Old 05-23-2005, 11:00 PM   #7 (permalink)
Got Gas!
Yeah, that's right. If you buy a pack of leads, you should get 5. 4 of them will go from the spark plugs to the distributor cap and 1 will go from the distributor cap to the coil. Just make sure that you do one at a time so that you connect the correct lead to the spark plugs. Won't run so good if get the firing order wrong. Done that plenty of times without thinking.
Old 05-23-2005, 11:04 PM   #8 (permalink)
Still confused...
Hmm, ok, well, that makes sense. I was thinking I can have my plugs/wires changed at a shop actually so not hooking them up correctly wouldn't be my problem...I'd do it myself but it's just that i'm 17, and this is my only car and i don't wanna mess up something bad... well, you get the idea.
thanks a lot for your feedback! i appreciate that~
Old 05-23-2005, 11:08 PM   #9 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
will be cheaper if you do it yourself.
just pull one cable @ a time. shop will charge you 20$ for pulling and installing cables.
1-10 hard work factor, with 10 being the hardest, this would rate as a 1 in terms of hard work factor.
skewe is offline   Reply With Quote
Old 05-23-2005, 11:19 PM   #10 (permalink)
Got Gas!
I'm certainly no mechanical genius but spark plug changing is pretty simple and you will save money. Mind you, saying that, I get mine done by a friend because the 3VZ-FE is a bitch to get to the rear sparks unless you have 2 elbows.
Old 05-23-2005, 11:23 PM   #11 (permalink)
Still confused...
hmm... we'll see. i'll be taking the car to the shop either way for shceduled maintance so yea...i dunno. my folks might be against me changing engine components.. i'll try but i dunno..
Old 05-24-2005, 08:37 AM   #12 (permalink)
Gameroom cash: $304355
hey guys.
-alex
If you "can feel the wire holding it vibrating" you may have one or two plugs that have become loose inside the head. Before doing anything else, get a manual and a torque wrench and torque the plug(s) you feel this vibration from, to factory torque specs.
Mike
Old 05-24-2005, 08:52 AM   #13 (permalink)
TN's ExercisePhysiologist
Bunthy's Avatar
View Bunthy's Photo Gallery
many are there, spark plug threads
seach button noob, you should use
NGK and DENSO, you should buy.
Be one with the force.
You'll like being blown
Bunthy is offline   Reply With Quote
Old 05-24-2005, 09:53 AM   #14 (permalink)
tC
^^^ someone just saw the movie
07 tC MT
-TRD RSB
-TRD Exhaust
Old 06-09-2005, 10:55 PM   #15 (permalink)
View toyota18's Photo Gallery
Australia
Hi.
Can I use iridium spark plugs in my 2001 2.2L 5sfe Camry?(Distributorless ignition.)But it says in the owners manual do not use single ground electrode plugs.I don't know why.May be some thing do with the waste spark ignition system? But I am not sure why.
I found Denso IK20, SK20R11 and NGK BKR6E1X-11 iridium plugs can be used in my type of car. Can I? what will be the service interval if I use them in my car?(original plugs can be used until 90000kms)
Thanks in advance.
toyota18 is offline   Reply With Quote
