stop light not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2005, 12:54 AM   #1 (permalink)
View mister Joe's Photo Gallery
2nd Generation stop light not working
Hi guys,
Few days ago my stop light "not working" went on in my dashboard. And like a good average Joe, I went to Kragen and got New bulbs ( I changed all the back bulbs), and changed the fuse for the stop light (20 A). Well, nothing happend!! still was not working.
I decided then to replace the stop light switch, and I checked (visually) the wiring in the trunk.
So that's where I am right now. "Stop light" not working is still on in the dashboard.
I think there is a short somewhere!
At this point, I am ready to bring it to a mechanic and spend some hard earned money.
any help would be appreciated!
mister Joe is offline   Reply With Quote
Old 05-25-2005, 02:31 AM   #2 (permalink)
View cheezthis's Photo Gallery
Hehe...my 90 Camry third brake light quit working awhile back too. I checked the obvious things, and found nothing wrong. I haven't fixed it yet, but would like to, so keep us posted.
1995 Acura Integra GS-R
1990 Toyota Camry V6 LE
cheezthis is offline   Reply With Quote
Old 05-25-2005, 05:11 AM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Have you checked the light failure sensor?
Its on the left side of the trunk by the power antenna (if you have a power antenna).
IIRC its a yellow box. Might have to remove some of the trunk lining to see it.
From Toyota ewd manual:
stop light s/w:
closed (continuity) with brake pedal depressed.
light failure switch:
1, 7 - 9: 12 volts with stop light s/w on
2, 3 - 9: 12 volts with ignition s/w on
"Skoolin' the unlearned!"
Old 05-25-2005, 07:21 AM   #4 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Or maybe your wiring is messed up
http://www.xclusive.bz
Old 05-25-2005, 08:13 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
^ He said he checked the wiring.
Old 05-25-2005, 09:57 PM   #6 (permalink)
2nd Generation
I checked the light failure sensor located in the trunk, it's yellow and I have no clue if it is working or not, I have no electric sensor or tool ,or knoledge on how to check it.
SO next monday is my day off, i'll go to the junk yard and get a couple of those sensor.
Is there any other things I could check before bringing the car to a mechanic or auto electrician.
(forget Toyota dealers, just to say hello, they ask you $170!!!)
thanks guys!!
Old 05-26-2005, 05:05 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
^ Open up the light failure sensor and look at the circuit board. See if any of the components or traces are burnt.
Old 05-31-2005, 10:46 AM   #8 (permalink)
So I went to the junkyard, got myself a couple of "lamp Failure" boxes, the one located in the trunk, behind the panel on the left.
And, And, And IT IS Vorking Kaptain!!!!! the WARP CORE in back on line!!!!
Stop light working again.........
thanks you guys for your help, now I can spend my money on someting else like computer parts..
Ciao
Old 05-31-2005, 10:55 AM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Sweet.
So it was the light failure sensor.
No prob.
Wanna buy me some computer parts too? I wouldn't mind upgrading. j/k
