Airflow meter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-25-2005, 07:04 AM   #1 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
2nd Generation Airflow meter
I was wondering if there is any other airflow meter that will work with the 2VZFE. Just wanted to grab another one and was wondering if I could use a 3VZ, 3SFE or 3SGE perhaps.
Thanks.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-25-2005, 07:44 AM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
3vz-e is a possibility, but it's probably just as small!
3vz-fe AFM is totally different. Way larger, but works on that backwards scale.
AFA anything else, I wouldn't know.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 05-25-2005, 08:14 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
one off the old supra 3.0 motor maybe... 7mg-somethig or other
that might fit.... they get used inplace of stock 3vz-e units so if your plug is the same it should fit maybe.... theyre same size as the 3v-fe ones i think (it shares teh same pod filter adaptor plate model numbre at auto barn
terrastrife is offline   Reply With Quote
Old 05-25-2005, 08:16 AM   #4 (permalink)
VeeZed
Wicked.. i basiclly want to try a different meter to see if mine is stuffed (i get error codes sometimes). Its tricky finding a good 2VZFE one...so anything that is basiclly "the same" is all I want. I dnt want to change anything in terms of flow or whatever..just wanna change over mine for a new unit.
Old 02-08-2006, 03:49 PM   #5 (permalink)
Boondock Saint
View 89SV21's Photo Gallery
I was wondering if I would be able to use the airflow meter off the 7mge or 7mgte to replace the crappy stock afm on my 89 gen 2. It has a 3sfe btw. If i were to do this would it mess things up and throw up check engine lights? thanks in advance
Nick
"Fur pie doesn't sell"
89SV21 is offline   Reply With Quote
