Recently had my engine (3vz-fe)rebuilt PP'd Etc etc etc...i finally get most of the exhaust in place today and go to start it for the first time since November(!). Given the gas is that old but still i should work. I hear the starter squeeling away but nothing will start i tried movin around the distributor a bit nothing worked. I smell strong fumes from the gas engine bay, i see no leaks anywhere. I tested if the sparks are sparking, they are....i check and listen for the feul pump to do its thing and hear it...wuts goin on...the only thing that really comes to mind is completely way off timing. ther is one hose i still dont have a home for but i figured it would make much of a diff as i was merely testing to see if it would start at all then if it did turn if off a sec l8r...heres a pic of wuts not connected besides a couple sensor connectors.
any ideas wut else to check? sumthing im being really really ignorant about and forgetting?
hose looks like the pcv that shouldnt do anything ...... not sure on the 3vz ..... but those sensors might be whats keeping you from starting the engine
^ and leaving it that way!
my car started up just fien after being in storage for 10 minths.. execpt for one spark missing (rats had crewed though the plug lead which now has and still has speaker wire there)
check compresssion?
i checked the feul pump...i can hear it when i turn the key right before ignition, if it didnt work i shouldnt beable to hear it i would assume, plus w/all the smell of the gas i cant see it NOT working , i wish it was the pump tho cuz that would be easy to target and fix
*how can i check compression, cant say ive ever had to b4?
ahhh...are you getting air in the motor...ie is the intake clogged....god knows animals think that is a good place to set up shop...that would do it as well.
Point your your distributor rotor to number one cylinder on the cap and check to see that the timing belt arrows line up on the pulley pointer for TDC .........Could be that the belt is way off???
i just took the chamber off the other day and it seemed clean enough, ie no animals
as for the belt i dunno, when it was put together it SHOULD, in theory have been almost perfect buuut we all know how theory holds up to reality w/cars...i def. had the belt in mind though and sumthin i need to check as well
wow just tried to start my car.................oil POURED OUT...and i cant tell wer the f** it came from, sumwhere just under the oil filtler (and it isnt the filter i obviously checked taht) i assume this COULD be my problem huh? i wonder y it didnt do that last nite when i tried to start it?!
