NEED URGENT HELP Indicators and hazard lights not working - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2005, 08:04 AM   #1 (permalink)
1999 Gen4 V6
AustSV21's Avatar
View AustSV21's Photo Gallery
2nd Generation NEED URGENT HELP Indicators and hazard lights not working
Hey everyone I need some help. My turn signals and hazard lights are completely inoperable. I have an 89 SV21 executive camry. I was just driving along and the indicators stopped working. I have checked/replaced the fuses for both the turn signals and the hazard lights to no effect. I removed the battery leads thus resetting the elec system and it worked for a bit, tried it again but didn't work. I have an immobiliser installed and when I press the button on it all the indicators work. I quickly spoke to the local mechanic who said the 'Flasher Can' is most likely broken. Could you guys please give me some advice, I have searched the forums but could not find this topic. The reason I say urgent is because it is pretty dangerous and illegal and my arm is getting tired from using it to signal Very Happy . Thanks.
AustSV21 is offline   Reply With Quote
Old 05-26-2005, 08:42 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
replace teh flasher can-- its probably in teh dash behidn hte glove box somewhere.. theyre like $5 from a patrol station, so cheaper elsewhere.
terrastrife is offline   Reply With Quote
Old 05-26-2005, 08:53 AM   #3 (permalink)
1999 Gen4 V6
AustSV21's Avatar
cheers man i thought it'd be expensive, ill try to get one tomorrow and let u know how I go
Old 05-27-2005, 07:18 AM   #4 (permalink)
1999 Gen4 V6
AustSV21's Avatar
Thanks for ur help guys. It turned out to be the flasher can (relay). Cost $38.50 from Toyota. On my Australian model it was located on the right side drivers side wall, above the fuse box. If anyone needs it I have photos of where it is located exactly and what it looks like.
Thanks again.
