check brake pads? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-26-2005, 06:24 PM   #1 (permalink)
Whats a Noobian?
sq_camry's Avatar
View sq_camry's Photo Gallery
check brake pads?
ok, i am hearing a squeeling noise and am getting tired, so today i popped off the right rear wheel to check the pads and cant figure out how to spread the calipers. basically all i did was take the wheel off and put it back on because i have no clue how to do this. help?
its a 98 le if that matters w/ the 5sfe
sq_camry is offline   Reply With Quote
Old 05-26-2005, 06:41 PM   #2 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $397060
iTrader Score: 13 reviews
spread the calipers...?
basically, just take off hte bottom screw, lossen the top one, and then flip up the entier caliper...simple as that ...
HaHa
Old 05-26-2005, 06:45 PM   #3 (permalink)
Whats a Noobian?
sq_camry's Avatar
what kinda tools will be needed?
alen wrench?
Old 05-26-2005, 08:23 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
12mm socket/wrench. One one each side of the caliper. You simply unbolt one and flip the entire assembly up.
You need to compress the pistons with a c-clamp to get them back on.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 05-26-2005, 10:55 PM   #5 (permalink)
Whats a Noobian?
sq_camry's Avatar
i talked to a friend and he told me how to do it, thx for the help tho
all i had to do, was take off the ebrake and put car in Neutral and the assemble slides right off
as for the front, i just took off both bolts and pulled off the retainers and pulled the pads from their sockets.
er, i also just wanna say that the oem pads suck, and i think aftermarket ceramic pads should fix the noise problem.
Old 05-27-2005, 08:24 AM   #6 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
14 mm on Caliper bolts, with 17 mm on Slide pins, at least on a Gen 3 95 2.2IL.
mandyfig is offline   Reply With Quote
Old 05-27-2005, 09:17 AM   #7 (permalink)
Where are we going today?
skewe's Avatar
View skewe's Photo Gallery
maybe ur rotors need resurfacing or the pads needs to be changed
it is also good to put some brake grease between the caliper and the pad. NOT the pad and rotor.
That will stop the squeak
skewe is offline   Reply With Quote
Old 05-27-2005, 12:19 PM   #8 (permalink)
Gameroom cash: $304355
The 98 is the same. I have both generations.
Incidently, the 98 4 cylinder 5SFE should have rear drum brakes. Did someone do a rear disc brake conversion on this car?
Mike
