tranny fluid drain/refill - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2005, 12:57 PM   #1 (permalink)
Still confused...
95WhiteCamry's Avatar
iTrader Score: 7 reviews
View 95WhiteCamry's Photo Gallery
3rd Generation tranny fluid drain/refill
Hi all. Quick question.
Toyota recomends a transmission fluid drain and refill every 60 k miles. However, i have heard many times that transmission fluid is not safe to drain and refill because it may then the transmission itself may begin to act up and break. Is that true? Much like brake fluid, I think the tranny fluid is not to be drained and refilled often. Is that true? Thanks guys
95WhiteCamry is offline   Reply With Quote
Old 05-28-2005, 02:52 PM   #2 (permalink)
tC
View 95camguy's Photo Gallery
you should change it every 30k miles. if you change the fluid and the trans dies soon after there was something more serious wrong. changing fluid should not kill a good tranny. check your fluid and take note of the odor and color. red fluid is what your looking for, and it shouldnt smell burnt either. brown or burnt smelling fluid should be changed.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 05-28-2005, 03:13 PM   #3 (permalink)
N/A bites
Tercel GTS's Avatar
That rumor applies to cars with 100k miles on the original fluid. If your car is fairly new then starting a fluid change habit is very healthy. I'd get the trans flushed at 30k and a filter change at 60k. Removing the pan and filter does not drain all the fluid, in fact only about half.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 05-28-2005, 04:03 PM   #4 (permalink)
Still confused...
hmmm, well my camry is an I4 at 99.5 k miles on it. i've only had it for less than two months and i dunno how the previous owner took care of it...so yea, thats why i am so undecided about actually draining the fluid and refilling.
Old 05-29-2005, 02:39 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Drain and fill or have it flushed.
Have the differential drained and filled too.
"Skoolin' the unlearned!"
