Hi all.
I'm trying to verify that it is indeed a bad wheel bearing causing the noise in our car, or get other ideas of the problem.
Symptom: clunkclunkclunkclunk noise, all the time car is in motion, increases speed with wheel speed.
Noise does NOT change when alternating between accel and decel, but gets quieter when turning in one direction, louder when turning in the other.
What has been done so far:
new CV axle on the side opposite the noise, no change
new CV axle on the side the noise comes from, very little change if any
slightly loosened the wheel bearing on the side the noise comes from and drove - noise increased
I originally thought that the cv axle on the noisy side was bad and causing the noise, since there was a good deal of rotational play in the wheel when the one noisy side was jacked up. Brought it to a shop, they replaced the OTHER side since the boot was ripped on that side, claimed no more noise. Wrong, but the rotational play was at least a little less. Brought it back and had them replace the other side, the play was further lessened, but not eliminated. I thought it would be gone completely, am I wrong? Anyway, once the play was lessened, I could at least shake the wheel side to side to try to detect wheel bearing play. After I picked it up, I brought it home and jacked up that wheel and could detect bearing play. I figured it was just loose. Today I loosened the bearing locknut (it was very tight) and retightened it after I drove around with it intentionally loose for a while to help diagnose. I couldn't feel the play in the bearing this time, but maybe you have to have the wheel in the right position around the clock to feel the play?
Here's a link to a 1.5MB video of the amount of rotational play from one drive wheel to the other. I guess my only other idea was that the female splines in the transmission are worn, and no matter what I do there will now always be this noise and play unless I repair the transmission. I don't want to believe that, but I also don't want to pay for the wheel bearing replacement only to be again disappointed that this noise is still there!
http://rapidshare.de/files/2037394/huh.avi.html
Thanks for any help!
