Timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-28-2005, 08:08 PM   #1 (permalink)
View arvintyper's Photo Gallery
Gen5 Timing belt
have you ever heard that Gen 5's 2AZFE engine is using timing "chain" instead of timing belt?
Is that true?
arvintyper is offline   Reply With Quote
Old 05-28-2005, 08:14 PM   #2 (permalink)
bronzemaxell's Avatar
Gameroom cash: $270360
View bronzemaxell's Photo Gallery
Is that true?
that is true, and i think it is an interference engine,
it also has Drive By Wire throttle body, distritorless
bronzemaxell is offline   Reply With Quote
Old 05-28-2005, 08:16 PM   #3 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
^ What a "pain in the ars" engine!
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 05-28-2005, 08:34 PM   #4 (permalink)
oh, so i don't need to change timing "chain" in the future?
although my 03 only has 20000km on it, already thinking about the future maintenance...
Old 05-29-2005, 02:43 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Timing chains still need to be replaced (they stretch over time), but not as often as a timing belt.
"Skoolin' the unlearned!"
Old 05-29-2005, 03:32 AM   #6 (permalink)
Toyota Employee
View Studly's Photo Gallery
Incorrect - a timing chain should never need to be replaced.
If for some reason it became noisy, then you may have to (expensive!), but it will last pretty much forever.
Studly is offline   Reply With Quote
Old 05-29-2005, 08:46 AM   #7 (permalink)
The Other White Meat
terrastrife's Avatar
chains will stretch but because ya still on the correct tooth, its ok, all that happens is that itll get a bit slack (if that) but all good still.
terrastrife is offline   Reply With Quote
Old 05-29-2005, 09:03 AM   #8 (permalink)
so ya!? coz I heard that Sentra never ever need to replace their chain
Old 05-29-2005, 09:21 AM   #9 (permalink)
where-ever there is a moving part, there is a wear and tear, and will need replacement in matter of time.
i guess if the engine dies before the timing chain, then it will never needed to be replaced.
Old 05-29-2005, 12:34 PM   #10 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Most of the time the chain will last the life of the engine. Ive seen plenty of engines with over 200K miles on them that have the original chain. Then again ive changed a couple due to worn chain guides (early 90's sentra), but even those were in the 150K mile range. As bronze said, any moving parts will eventually wear down.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
