Engine to trans-axle bolts torque specs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-29-2005, 03:33 PM   #1 (permalink)
View call831's Photo Gallery
Unhappy Engine to trans-axle bolts torque specs
I'm replacing the engine (5S-FE) automatic trans-axle on our 96 Camry. I'm using the Haynes service manual and I can not find the torque specs for the 14mm and 17mm external bolts that attaches the engine and trans-axle. Please help, I could not find using a search...
call831 is offline   Reply With Quote
Old 05-30-2005, 07:14 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
This is the only thing I could find in my Chiltons manual:
12mm transaxle housing bolts = 47 ft. lbs.
10mm bolts = 34 ft. lbs.
Rear engine mount bolts = 38 ft. lbs.
Torque converter mounting bolts = 20 ft. lbs.
Maybe their refering to the size of the bolt threads, not the size of the bolt head (socket size). Makes sense to me cos there is no 12mm or 10mm bolts holding the tranny to the engine (block).
"Skoolin' the unlearned!"
Old 05-30-2005, 12:48 PM   #3 (permalink)
Gameroom cash: $304355
Why not take a look at the Generation 3 manual posted at the top of this forum.
Mike
