NEVER machine away a contact surface of a wheel. This will weaken the strucutral integrity of the wheel. Also, if you machine away too much, it may cause the closed lugs to reach the end of the stud but not hold the wheel down.
Like I've said many times, the offset is COMPLETELY DEPENDENT ON THE WIDTH, not the size. so whether its 19 or 18 doesn't matter, because you are offsetting the bigger rim with low profile tires - the overall diameter should be relative close.
As for the rim width, I'm guessing it would be a 19 x 8, in which case 40 or even 45 can be done if you are going with 225 or less width tires. Mine is 18 x 8 with 45 offset.
I'm SUPER, thanks for asking;
All things considered I couldn't be better I must say.
I'm feeling SUPER, no, nothing bugs me;
Everything is SUPER when you're...
SUPERCHARGED!
