Originally Posted by 4DoorsofFury
Im very confused about the relationship betweent the S series engines and the F and G models. i first planned to get a full engine swap with a 3s-gte, but now im wondering is there a way swap from FE to GE without a whole engine swap? did anyone understand that and do i make sense?
Ok, certain years of 5S-FE ( early 3rd Gens ) can use the 3S-GTE head ( basically, like a hyrbid motor). With minor or no modification, need to fit the head onto the 5S-FE short block. Ok, I'll let the cat out of the bag... here's the how to do hybrid motor from your friendly neighborhood Wraith:
°Drill and tap oil filter side of block to accommodate turbo oil feed. Drill and tap the stock 5S-FE oil pan for turbo oil return line. Or use the 3S-GTE oil pan ...
°Ported oil channels for better and less restrictive oil flow.
°Port and polished 3S-GTE oil pump.
°3S-GTE water pump.
°All new bearings including thrust bearing, (clearance at 0.002).
°Balanced crank and crank assembly.
°Forged Pauter I-beam connecting rods, for 5S-FE.
°87.5 mm Forged pistons with 8.8:1CR and custom pin hieght(which is stock on USspec. and J-spec. 2nd gen 3S-GTE), but you can run any compression you want.
° .95mm Head Gasket or Deck block to smooth finish for steel gasket setup. And you can run any thickness you want.
°Custom flywheel ( I havent gotten this far in my research).
°Thrust Bearing ( 5s-fe or 3s-gte depending with tranny your running).
°New engine gaskets and seels.
°Fitting for 3S-GTE dip stick.
°Oil fittings and braided lines.
°Modified 5SFE fuel rail to fit 3S-GTE head with bosch injector setup.
°Boost dependant fuel regulator.
°3S-GTE cambelt.
°3S-GTE cambelt tensioner.
°3S-GTE idler pulleys.
°3S-GTE head bolt or ARp head studs.
I think thats it off the top of my head. But, I'll add more later if I remember anything extra... Hope this helps...
Addition to the above information: 8/25/02 7:01pm
° 3S-GTE ecu
° 3S-GTE igniters
° 3S-GTE harness needs to be mated to the 5S-FE harness
° 3S-GTE map sensor
° 3S-GTE MAF sensor
° 3S-GTE cap , rotor, wires
° 3S-GTE or better fuel pump
° 3S-GTE 440cc injectors
